AutoCAD Raster Design Forum
Error message using Autocad/Rasterdesign 2011
0 REPLIES 0
Message 1 of 1
TWJ14
473 Views, 0 Replies
I have a trial version of Autocad and Rasterdesign 2011 loaded on my PC.
After inserting a scanned image into Autocad/Rasterdesign and saving the file as a dwg.
I attempt to do some clean up work on the raster image – using the rasterdesign
Tools from the drop down menu -  Raster/Raster Entity Manipulation/Create Region/Rectangle.
After I outline the area with the rectangle tool , I get an error message – Autocad Error Aborting
Fatal error: Unhandled access violation reading 0x0000 exception at 10ecdeeh
When I pick ok – it gives me the message That Autocad cannot continue- You can attempt to save changes to a particular location. Then it says after saving you can open or recover the file.
So basically it blows out of autocad.
I have attempted this numerous times and the same thing happens.
Does anyone know what may be causing this.
0 REPLIES 0
”Boost
