AutoCAD Raster Design Forum
Does "burn in rotation" alter the color space?
2 REPLIES 2
567 Views, 2 Replies
I found the little bug ?
I have a 256 color scaned map. It is georeferenced with rotation.
1. I made a crop and save it with export without burn in rotation.
2. I converted tot grayscale via histograms and I exported it without burn
in rotation.
3. I checked the file with ACDSee and I got properties colo:256 grayscale.
OK.
4. I exported again the grayscale image but now with "burn in rotation"
checked.
5. I checked file with ACDSee and I got properties color: 256 !!! ?
Now, I try to put them in the same ric (MG Raster Workshop), I got below
error message.
"The color space of image : ... path xxx.tif does not match that of the
first file referenced by the raster image catalog."
Thanks!
Raster Desgin R3.
Albert Kalman
2 REPLIES 2
On Mon, 6 Oct 2003 12:22:32 -0700, "Albert Kalman"
>in rotation.
>OK.
>checked.
No.
I tried this on Raster Design 2004.
1. I inserted SanFran.tif (from the samples dir).
2. I used Histogram to convert to grayscale.
3. I exported the image to orig.tif
4. I rotated the image.
5. I exported with burn in rotation to new.tif.
6. I inserted both images into AutoCAD.
In Tools->Properties, both images are listed as grayscale.
I loaded both images into Paint Shop Pro. Both images are grayscale.
Phil Daley
Please try with Raster Design R3 (Autodesk Map Series R5), Check with ACDSee
and try to make a ric for MG. As I found the problem.
I can post the 2 sample on customer file.
Thanks!
Albert Kalman
"Phil Daley" wrote in message
news:apq5ovov96bgdon24lru2i5ca4hju0n6pv@4ax.com...
burn
> >in rotation.
grayscale.
> >OK.
> >checked.
> No.
> Phil Daley
”Boost
