AutoCAD Raster Design General
Valued Contributor
david.dixon
Message 1 of 2 (269 Views)
Accessing info on my old Support Requests
269 Views, 1 Replies
08-07-2013 12:38 PM
I am having an issue with installing Raster Design 2011 onto a Win7-64bit system; it will not install.  I had the same problem at my previous employer where I had access to Autodesk support thru subscription.  I have recently moved to another employer and no longer have this access.  I am sure I worked with an Autodesk tech to resolve the issue but I do not remember what the fix was.
Is there anyway someone from Autodesk might be able to look the solution up for me?  The fix is not listed in the knowledge base. And I'm pretty sure it's the same problem.
Dave
David Dixon
Senior Civil Designer
Google+
philip.s
Message 2 of 2 (259 Views)
Re: Accessing info on my old Support Requests
08-07-2013 02:24 PM in reply to: david.dixon
I'd be more than happy to look up old support requests David!
Would you mind sending me a Private Message with your prior email address and any additional details that might assist me in locating the case?
Philip Schmelzer
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
