• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD R12/R13/R14 DWG Format Archive
    *Moseleym
    _image Demand load failed due to missing module.
    294 Views, 1 Replies
    03-01-2000 05:34 AM
    Trying to insert a Raster image into a drawing is failing with this
    message in the text command window.
    Command:
    Command:
    Command: _image Demand load failed due to missing module:
    Description: ISM
    Module Path:
    Unknown command "IMAGE". Press F1 for help.
    Simply, I am trying to insert a raster image and my Autocad14 is now not
    taking the command from the pulldown menu Insert. This could possibly
    have to do with some system variables, but I am unsure obviously posting
    here.
    Thanks~
    mm
    Please use plain text.
    *Byrnes, Dave
    Re: _image Demand load failed due to missing module.
    03-01-2000 11:15 AM in reply to: *Moseleym
    Try running the ARX command at the command prompt. Enter L for Load, and a
    "Select ARX File" window should pop up. If ISM.ARX is in the list, select
    it, then click Open.
    You should only have to do this once; next time you start AutoCAD, the
    setting should still stick.
    If ISM.ARX is *not* listed in the window that pops up, then there's a
    problem with your AutoCAD support path.
    Dave Byrnes/Bowen Island BC
    Autodesk Forum Moderator Program
    Moseleym wrote in message
    news:38BD1C61.CC6C8A2@ci.concord.nc.us...
    > Command:
    > Command:
    > Description: ISM
    > Module Path:
    > here.
    > Thanks~
    > mm
