• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD R12/R13/R14 DWG Format Archive
    *Engineers, Metz
    X-clip
    92 Views, 10 Replies
    03-01-2000 04:38 AM
    What are the pro and con of using X-clip (versus using a view in Paper
    space)
    Please use plain text.
    *McDowell, Greg
    Re: X-clip
    03-01-2000 06:56 AM in reply to: *Engineers, Metz
    Another advantage to X-clipping has to do with demand loading. If you set
    INDEXCTL = 1, 2 or 3 AutoCAD creates either (and I'm not sure of the order
    here) layer indexces, spatial indexces or layer and spatial indexces. If
    demand loading is enabled in the drawing you've got the file referenced into
    (XLOADCTL=1) then AutoCAD only loads the information it needs to display the
    drawing.
    The long and short of this is that if you create layer and spatial indexces
    and enable demand loading you will see an improvement in performance if
    you've got the layers frozen in the referenced drawing and/or the drawing
    X-clipped.
    *bwajwt
    Re: X-clip
    03-01-2000 06:59 AM in reply to: *Engineers, Metz
    One of the main advantages of using paper space for multiple views of the
    same drawing is that you only xref the source drawing once, so there is only
    one set of layers associated with that drawing. If you xref the drawing
    multiple times, using xclip to create your views, you end up with an entire
    new set of layers for every version of the xref. You can overcome this
    inconvenience to a certain extent by using the Bonus Tool Layer Manager, but
    its still a little bit of a hassle.
    Another major advantage is that plotting is so much easier if you always
    xref your titleblock into paper space, and display your drawing in a paper
    space viewport, set to the proper scale. For some reason, the average
    draftsman has a really hard time understanding the concept of scale factors.
    With paper space, plotting is always 1:1 and nobody has to do any thinking
    to get the plot to come out right every time.
    There are downsides to using paper space. In my opinion, paper space is
    unfit for anything except arranging views and placing drawing titles. For
    one thing, most Autocad commands cannot be invoked transparently while in
    paper space, so forget dimensioning a large drawing in paper space.
    Secondly, the more viewports, the more the computer bogs down. And thirdly,
    depending on your LTSCALE/PSLTSCALE strategy (no, I'm not going there now),
    the line types may not come out right in a paper space viewport. When this
    situation comes up, I usually xref the drawing into paper space at
    1/dimscale to make the linetypes come out right. But this means that you
    have to do all of your drawing in the source file, which sometimes negates
    the advantage of xref'ing in the first place.
    Keep in mind, all of my opinions are based on producing architectural
    drawings, and these points may not be valid for anybody else. With that in
    mind, I use paper space viewports about 90% of the time (to display
    different views of the same drawing) . I use clipped xrefs about 10% of the
    time (when the linetypes are a problem).
    JT
    Metz Engineers wrote in message <89j4df$2r718@adesknews2.autodesk.com>...
    >space)
    *dePascale, Chris
    Re: X-clip
    03-01-2000 07:47 AM in reply to: *Engineers, Metz
    The pros of xclipping are that you have unlimited control over the shape of
    the base drawing (even in a viewport) Rectangular viewports may interfere
    with notes that are going into paper space, so it is very convenient to have
    a means for "erasing" parts of the xref so that they don't show through into
    the viewport. There is one drawback that I have found, however (it is a
    question that I posted to this newsgroup a while ago and got no response, so
    I'll assume that there isn't a known way to get around it). Linetypes that
    have dots in them (such as dashdot) will only generate with a space where
    the dot should be. So dashdot looks like dashed with bigger spaces. When
    xclip is turned off, the dots come back. So my advice would be to be
    cautious when you know you are going to xref and xclip, and pay close
    attention to the drawing once you have clipped it. We didn't figure this
    problem out until the client asked us why the linetype didn't match the
    legend, and that's not the most enjoyable way to find problems with AutoCAD!
    news:89j4df$2r718@adesknews2.autodesk.com...
    > space)
    *McDowell, Greg
    Re:
    03-01-2000 09:33 AM in reply to: *Engineers, Metz
    Opps... ignore the accidental post.
    I feel an urge to clarify...
    > If you xref the drawing multiple times, using xclip to create your views, you
    Rather than xref the drawing multiple times copy the first reference and
    re-clip. The xref is only loaded once. Use demand loading (INDEXCTL=3 in base
    drawing XLOADCTL=2 in sheet drawing) so AutoCAD doesn't try to regen what it
    doesn't need to.
    As an alternate you could xref your titleblock at 1:1 and scale all your xrefs
    down appropriately. I don't do this but I've been thinking about it. But I
    agree... the average drafter doesn't understand scale factors let alone the
    average Architect!
    Which commands do you have problems working transparently in PaperSpace? I know
    in R13 there were all kinds of issues with PaperSpace and I avoided it like the
    plaque... try panning or zooming in R13 - man what a pain! As for dimensioning
    in PaperSpace... it works great! Just set your DIMLFAC to the scale factor of
    your drawing and go to town. Viewports do tend to bog a computer down somewhat
    but I routinely work with drawings that have 20 or more viewports and haven't
    noticed a major problem. I think it has a lot to do with how I use x-clipping.
    If I've got a base xref that I'm viewing through viewports to create enlarged
    drawings I make sure that there is only enough information clipped to show up in
    the viewport. I copy the xrefs and re-clip as needed to fill out my sheet.
    With demand loading working for you things go really fast. But the linetype
    problem has me stumped... I never have any problems getting them to look like I
    want. Both LTSCALE and PSLTSCALE are set to 1 and the viewport handles scaling
    of linetypes.
    What are your thoughts on my thoughts?
    *bwajwt
    Re:
    03-01-2000 03:22 PM in reply to: *Engineers, Metz
    Greg:
    you
    Copying the xref multiple times doesn't accomplish what we need to do. We
    draw a base floor plan that contains walls, doors, windows, and dimensions.
    Dimensions for all the different scaled views are placed on this base plan
    top of each other on separate layers. Then, layers are selectively turned
    on or off in each view. If we use paper space, we use the "freeze in
    current viewport" command to get the proper visibility. If we use multiple
    xrefs, we have to rename each xref so we get a unique set of layers for each
    view so we can selectively turn dimension layers on or off.
    xrefs
    I
    >average Architect!
    Yes, we do xref our titleblock into paper space at 1:1. And we xref our
    base plan into model space at 1:1. Then we place notes and keys on top of
    the model space xref.
    know
    the
    dimensioning
    I have to admit, it was R13 where I decided not to use paper space for
    drawing because of the transparent command problem. I got so out of the
    habit back then, that I haven't seriously tried to see what R14 can or
    cannot do. But its really academic. We find that, for us, dimensions are
    much better in model space in the base plan. A typical architectural base
    plan gets tweaked many times before it goes out to bid. Having the
    dimensions right there in the same drawing file with the walls you are
    changing makes changes much quicker and accurate (for us).
    linetype
    like I
    scaling
    >of linetypes.
    I know this is kind of a repeat of the other thread, but for the sake of
    continuity, here's how I do it. Set LTSCALE to the plotted scale factor,
    PSLTSCALE to 0, and use linetypes that display correctly at 1:1. Its clear
    to me that your method works just fine, too. The only difference I can see
    is that with my system you have to place line entities at a scale factor of
    1 and with your system you have to place line entities at a scale factor
    equal to dimscale. Is this the way you see it, too? And can you think of
    any inherent advantage (or disadvantage) to either approach? What do you
    think?
    JT
    *McDowell, Greg
    Re:
    03-01-2000 04:19 PM in reply to: *Engineers, Metz
    That's more or less what my firm does too... but I hate it. So much so that I
    took it upon myself to modify the system on this project (much to the alarm of
    the old school). So far everthings working great. My only beef with the "old"
    system is that I can't modify my annotations when I modify my text.
    Consequently I have to move back and forth between the files to accomplish what
    I want. Furthermore I find it nearly impossible to really organize a sheet
    compositionally with my dimensions in the base file. There is a system put out
    by the AIA called ConDoc which sort of brings together all the best practices
    for dimensioning and noting a drawing. It was put out years ago and doesn't
    directly refer to CAD but it does talk about things like placing your dimensions
    on the edges of your drawing area to free up space internal for annotations.
    When you put dimensions in the base file you (we) typically place them just
    about as close to the walls as we can to ensure that they actually show up on
    the plottable sheet. What you end up with is, IMO, a jumbled, hard to read
    mess. Maybe if our users were more skilled this wouldn't be as much of a
    problem. Then there's the whole issue of layer management that always seems to
    come up for us when we try to put too much in the base file... YUCH!
    Actually what I was suggesting was that I could make an arguement for getting
    rid of PaperSpace altogether. Sequence... xref titleblock in ms at 1:1... xref
    base files in ms at 1/scale factor... xclip as needed... layer control as
    needed. Viola! This will work as long as you don't need some layers on and
    some layers off (sorry... make that FROZEN... off bad...) in the same sheet file
    (such as multiple scales or floor plans and reflected ceiling plans). If you're
    doing that then yes... you either need to use ps or xref the file multiple times
    with different names (not a great idea).
    I really think that the methodology my office uses has a direct relationship to
    how previous versions of AutoCAD worked. I'm like you... I used to hate
    PaperSpace with a vengenance. Then, with R14, I decided it was tolerable. Then
    I, quite by accident, figured out that I could dimension in PaperSpace and still
    have it associative. And that, as they say, was that. I was hooked. Still am.
    > think?
    About the only disadvantage I can see is that you actually have to do
    something. I mean if I create a new drawing (without a template) LTSCALE and
    PSLTSCALE are already 1. I never even thought about doing it your way. What
    advantages do you see to your system?
    I'm not sure I get what you mean by "place line entites at a scale factor." In
    my base file I set my LTSCALE to whatever my DIMSCALE is (we've actually got
    buttons that take care of a lot of this for me). I create my lines with what
    ever linetype I think I need. If I need it smaller or wider I either pick a new
    one or modify my ACAD.LIN file to give me what I need. I know I could modify
    the entity to have a different scale factor (and I assume that's what you mean)
    but to me that's like making an entiity something other than BYLAYER which is
    for me (almost) a cardinal sin. (I say almost because I actually do it quite
    frequently but only when I don't feel that an entire new layer to manage is
    necessary for only a few lines.)
    *Medina, Alfredo
    Re: X-clip
    03-01-2000 05:11 PM in reply to: *Engineers, Metz
    Quinton...
    This reminds me of a topic that I would like to talk about. How to arrange
    the information in model space, so that it is comprehensible for other people
    who work on the same drawing.
    I draw rectangles in model space, on the defpoints layer. These rectangles
    are arranged in rows. They have a tab on the upper left corner, so that they
    look like the icon that Windows uses for directories. In the tab, I write in
    big letters one or two words describing the contents of the rectangle. For
    instance, DETAILS , another rectangle´s tab can have something like
    ELEVATIONS, and another one says MASTER XREF-(XCLIP). Below every detail I
    write a letter or a number: A , B , 3 , etc... also on Defpoints. When I go
    to Paper Space and try to create a viewport, I turn on the "Airplane" that is
    "Aerial View". Then I use the pan option inside Aerial View. Then, it is very
    easy for me to find, let´s say Detail #3 inside the DETAILS "folder". It
    helps other people find information in my drawings, too. If they want to add
    a new frame type or door type, they find the rectangle or "folder" with that
    name on the tab, and put them there. The tabs also say, as I explained above,
    if an x-ref is an x-clip.
    By the way, another advantage of using X-clips is that it reduces the size of
    the drawing. Compared with the same drawing with the same X-refs but without
    X-clips.
    Alfredo Medina
    Quinton Mcdaniel wrote:
    > Well first you want to make sure that who ever might work on the drawing
    > knows the drawing has been x-cliped.
    > Pro Xclip in R14 you can clip in polygon where a viewport can only do
    > rectangles this is the best feature although I hear that 2000 can do
    > irregular shaped viewports. I makes it possible to hide information on a
    > drawing that you might not need to see.
    > I really cant see any Cons besides just make sure that who ever opens the
    > DWG knows that it has been X-cliped.
    > > space)
    *Mcdaniel, Quinton
    Re: X-clip
    03-01-2000 05:41 PM in reply to: *Engineers, Metz
    > space)
    *bwajwt
    Re:
    03-02-2000 07:14 AM in reply to: *Engineers, Metz
    Greg:
    practices
    doesn't
    dimensions
    annotations.
    ConDoc used to be our bible in the board drafting days. And you're right,
    there's much about sheet composition in there that is just as valid for CAD
    drafting as board drafting.
    on
    >problem.
    The old standard was, the first string of dimensions should be 3/4" away
    from the object, and each additional string should be 1/4" from the
    preceding one. And all walls that touch an exterior wall are dimensioned
    with an exterior string, rather than a string running through the interior
    of the building. But even with all these rules, dimensioning is still as
    much an art as a science.
    > Then
    still
    Still am.
    This is brand new information for me. I'm going have to go check it out.
    a new
    Does this mean you have a different defined linetype for each scale factor?
    If so, this seems like more trouble than using a single set of linetypes
    that work for every scale via the varying LTSCALE setting.
    mean)
    is
    quite
    I couldn't agree more.
    By the way, thanks very much for the lively debate. It seems that whenever
    I suggest to some people in this NG that their LTSCALE/PSLTSCALE strategy
    may not be the only one or the best one, they seem to get offended and just
    cut off the discussion. I really appreciate your frankness and your ability
    to explain and analyze. I have found this thread very helpful.
    JT
