AutoCAD R12/R13/R14 DWG Format Archive
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Melissa
Polylines/ Busellato/ Autolink
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
389 Views, 2 Replies
03-10-2000 08:29 AM
I need to know if it is possible to draw a polyline with one end being zero
and the other being anything greater than zero. I am trying to desiginate
the tool direction with this polyline that appears to look like an arrow.
If anyone is using Autolink to convert their drawings into G-Code and can
assign a tool direction in another way, I would be interested in reading how
you are accomplishing this. Thanks Melissa
*Furman, Paul
Re: Polylines/ Busellato/ Autolink
Options
- Highlight
- Email to a Friend
03-10-2000 10:52 AM in reply to:
*Melissa
Do you mean z elevation other than 0? 3Dpolys will do that or changing your ucs.
If you mean width, that is easy, built into the pline command (starting
width/ending width).
Options
- Highlight
- Email to a Friend
03-20-2012 01:56 PM in reply to:
*Melissa
You need to make sure your polyline is drawn in the direction of your wanted tool path. select your polyline and hit edit vertex and make sure its moving in the direction that you want. the polyline arrow needs to be on an endpoint, and needs some elevation to ramp in. hope this helps.
