• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD R12/R13/R14 DWG Format Archive
    *Coggeshall, Andrew
    Open/Saveas dialog boxes are gone
    25 Views, 2 Replies
    02-27-2001 12:32 AM
    After I was finished using the batch plot utility yesterday a noticed that
    when I use the open or saveas commands I do not get the dialog boxes just
    command line requests. I thought that maybe the batch plot utility had
    changed a system variable or some other setting and it do not get set back
    to the default.
    Please use plain text.
    *Coggeshall, Andrew
    Never mind. Read "Print Window?" post below. Was the filedia variable.
    02-27-2001 12:39 AM in reply to: *Coggeshall, Andrew
    "Andrew Coggeshall" wrote in message
    news:E4C1431295735DF25768A6F1C69F7C7D@in.WebX.maYIadrTaRb...
    > to the default.
    *Lincoln, Tracy W.
    Re: Open/Saveas dialog boxes are gone
    02-27-2001 01:54 AM in reply to: *Coggeshall, Andrew
    FILEDIA1
    You should also look at CMDDIA, ATTDIA, ATTREQ by typing them in at the
    command prompt and hitting F1
    Please DO NOT send technical requests to me via private e-mail
    Tracy W. Lincoln
    Assistant Moderator, Autodesk Discussion Groups
    http://discussion.autodesk.com
    > to the default.
