• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD R12/R13/R14 DWG Format Archive
    New Member
    Moving currently running instance of R13 to Windows 95 VM.
    256 Views, 3 Replies
    09-12-2012 11:51 AM
    Hello everyone.  There is a long story and there is a short story.  :-)  Here is the short story version.
    My client has an instance of R13 on his Windows 95 system and CDs are corrupted and no other CDs around with R13. I have copied over the installed directories from the physical 95 system to the Windows 95 VM I created and encounter some errors and I need a clean running instance, just like it running on the current box.  My Win 95 VM instance runs flawlessly.  I am only having issues with the R13 folders that I simply copied over.  Could someone help me identify the solution(s) with the errors I'm running into?
    Thanks.
    craig
    Please use plain text.
    Re: Moving currently running instance of R13 to Windows 95 VM.
    09-12-2012 12:05 PM in reply to: NonAutoCADUser
    You're probably missing some dll files from the orginal Windows/System directory
    Are getting any error message such as 'Missing MS......DLL'
    Video and mouse drivers can also be a pain with Virtual Machines
    -David
    New Member
    09-12-2012 02:52 PM in reply to: DavidBethel
    Hello David.  Thanks for responding so fast.
    No, I'm not getting any missing .dll pop ups.  I grabbed some screen shots of the error happening.  I'm attached an Errors.pdf file.
    Thanks for your help.
    craig
    09-13-2012 04:39 AM in reply to: NonAutoCADUser
    Have you or can run _.config ?
    Or, run acad.exe -r from the command line.
    My guess is that the configio error is either video or keboard / pointer invalid configurations.  -David
