• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD R12/R13/R14 DWG Format Archive
    Member
    johnggold
    Exporting Single Layer DXFs in R12 Format
    321 Views, 5 Replies
    07-01-2011 08:51 AM
    We work with a range of machines that can read single layer DXF files in R12 format.
    However, we start with DWG or DXF files from Customers that are multilayer, and although we reduce the polygon info to a single layer, when we check the exported DXF there are normally 4 layers.
    we always seem to see 4 layers, even when Customers export in R12 format for us.
    This means that we can receive a 200k file with only 20K data, and we have to use a text editor to remove the first three layers.
    We assume that there is a better way to ensure that Autocad does not output three unwanted layers which are very large and contain no useful data.
    Can anyone help.
    Please note that the required data are always 2D polygons.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Exporting Single Layer DXFs in R12 Format
    07-03-2011 10:28 PM in reply to: johnggold
    Freeze or turn off the layers not needed, then when dxfout, use Options as shown and select only the objects you need.
    Member
    johnggold
    07-18-2011 04:48 AM in reply to: Patchy
    This does not seem to work.
    Even when a single layer is selected, the file still contains multiple SECTIONS and dummy LAYERS. Depending on source, there are various differences. Mostly there are 4 sections of which only the last has useful information. This is all we need.
    0
    SECTION
    2
    ENTITIES
    0
    LINE
    8
    APS_GEOMETRY
    10
    508.000
    11
    508.000
    20
    117.000
    21
    10.000
    0
    LINE
    8
    APS_GEOMETRY
    10
    508.000
    11
    10.000
    20
    10.000
    21
    10.000
    0
    LINE
    8
    APS_GEOMETRY
    10
    10.000
    11
    10.000
    20
    10.000
    21
    117.000
    0
    ARC
    8
    APS_GEOMETRY
    10
    319.340
    20
    128.772
    40
    309.391
    50
    101.210
    51
    182.264
    0
    ARC
    8
    APS_GEOMETRY
    10
    199.043
    20
    128.772
    40
    309.390
    50
    357.736
    51
    78.790
    0
    ENDSEC
    0
    EOF
     Can you help us get to this point automatically. I'm getting fed up with text editing!
    Thanks.
    *Expert Elite*
    pendean
    07-18-2011 07:05 AM in reply to: johnggold
    Unless this Old-School solution is not old enough for your AutoCAD version, turning FILEDIA off then starting DXFOUT command give you the option to SELECT OBJECTS, which allows you to limit what gets exported to DXF.
    Another option: WBLOCK your layers to single DWG files and DXFOUT those new files.
    All the above can be automated with lisp, scripts etc.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    johnggold
    07-18-2011 08:00 AM in reply to: pendean
    Option 2 does not work. Already tried it. Leaves dummy layers in the file.
    Tried option 1. Not a lot of difference to Option 2.
    We can pull in a working DXF in the latest Autocad 2010 version, then save it again it gets substantially larger. Surely there must be a way of doing this without writing an application. We only use AutoCAD for the task of conversion.
    If we have to, we would have to write a standalone routine that :
    1. Finds the first LINE or ARC command in the file by seeking sequentially.
    2. Seeks in reverse to the first layer command found.
    3. Extracts the layer in its enirety.
    4. Tops and tails and export.
    This assumes that LINEs and ARCS are in only one layer.
    Has anyone tried this within AutoCAD? We need an application that works with most recent versions of AutoCAD.
    *Expert Elite*
    pendean
    07-19-2011 05:45 AM in reply to: johnggold
