AutoCAD R12/R13/R14 DWG Format Archive
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Downloadin g problems for 3rd party hatch patterns.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Keep them separate, right on
, why do people edit the acad.pgp ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OP what happens if you type OPTIONS on the command line?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
With ACLT 98 when typing "OPTIONS" on the command line, reply is "UNKNOWN COMMAND"`.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Patchy, as requested here is an attachment with the Culture Stone Drystack hatch pattern installed in the Bhatch file. Saved it as a txt file. The cs_drystack is loaded after the last predefined hatch pattern ZIGZAG. Remember, I'm running ACLT98. I tried typing "options' in the command line and the response is "Command Not Found". When I go to Bhatch from the pull down tab I get the predefined patterns only, nothing in user-defined nor custom. When I click on custom, the custom pattern box becomes active with the last used predefined default pattern name still visible but....greyed out in the box just above. When I type in "cs_drystack" into the custom box, the response is "unknown pattern name".
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Everything looks good, except you forgot to put a ; (semicolon) at the last line of the file.
Just put one ; by itslef and it should work
Like this:
45,34.826,21.8,27.0910285542,27.0910285542,0.54182
135,4.5592,23.715,27.0910285542,27.0910285542,0.54
45,27.968,30.995,27.0910285542,27.0910285542,0.541
0,27.547,1.4942,0,38.3125,1.9539,-36.3586
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, added the semi-colon after the last line. Saved it, closed down, rebooted, reopened a dwg file, and...nothing changed. Rechcecked the aclt.pat file and the semi-colon is still there. No cs_drystack hatch pattern. Nothing in the custom category, nor predefined nor user-defined. Tried typing in "cs_drystack" in the custom pattern...reply is "no known pattern".
I even took out the space between the last predefined hatch pattern and the cs_drystack hatch pattern...no change.
This is the only copy of the AutoCAD LT98 on this computer, so it can't be due to multiple programs.
I signed up with Culture Stone support last Friday. Still waiitng for administrator approval to sign in. Maybe they have an answer.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do this for me, at the command line type in:
(findfile "aclt.pat") with the brackets like that, what does it prompt after you hit enter.
