• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD R12/R13/R14 DWG Format Archive
    Active Member
    Comma in dimension text?
    218 Views, 2 Replies
    02-27-2001 01:14 AM
    Is there a way to have a comma in dimension text, WITHOUT using a text override? For example, dimensioning a line that is is one thousand feet long, is displayed in AutoCAD as 1000'. Is there a way for it to automatically display 1,000' - using the comma to mark the 'thousands' place?
    Please use plain text.
    *Lincoln, Tracy W.
    Re: Comma in dimension text?
    02-27-2001 01:56 AM in reply to: Joel_at_MEA
    If you set the Primary units to use Windows Desktop.
    Please DO NOT send technical requests to me via private e-mail
    Tracy W. Lincoln
    Assistant Moderator, Autodesk Discussion Groups
    http://discussion.autodesk.com
    > place?
    Active Member
    Re:
    02-27-2001 11:41 AM in reply to: Joel_at_MEA
    Thank you!
