AutoCAD R12/R13/R14 DWG Format Archive
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Can't boot up rev 12
- Highlight
- Email to a Friend
I am strictly using DOS.
I try to launch Autocad from the command prompt or the Dosshell and get the same results.
- Highlight
- Email to a Friend
On the odd chance that your acad.dcl file is corrupt, try this one. Don't forget there may be two instances, one in the acad directory and one in the support directory. Replace them both.
Gne
- Highlight
- Email to a Friend
The computer loads into a program called Point and Shoot. From there I can goto the DOSSHELL, Windows, or other sub directories and programs.
- Highlight
- Email to a Friend
Download a Dos 6.22 boot disk here .... ...
http://www.bootdisk.com/bootdisk.htm
Use it to boot your computer and see if Autocad will then run.
Gene
- Highlight
- Email to a Friend
I boot up on DOS onto a program called Point and Shoot which allows me to choose Dosshell, Windows, Autocad etc.
- Highlight
- Email to a Friend
Thanks. I'll give them a try and post the results.
- Highlight
- Email to a Friend
What I'm suggesting is that you not use Point and Shoot but rather boot with a Dos 6.22 boot disk and run autocad from there.
If you are not successful then I'm out of ideas.
Gene
- Highlight
- Email to a Friend
EUREKA I've done it. Thanks for all your help Gene. When I set up the computer to run Autocad I changed monitors. Everything worked fine on the monitor but I couldn't boot up Autocad. I remembered it had a monitor configuration on setup but thought they were the same. Just to confirm that was not the problem I installed my old monitor and auto cad came up just fine.
Now I can get back to drawing. Thanks Again
Mal
- Highlight
- Email to a Friend
All's well that ends well.
Gene
- Highlight
- Email to a Friend
It's possible to access R12 for Dos through a window in Win3.1
I can post instructions if anyone is interested.
Gene
