• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD R12/R13/R14 DWG Format Archive
    Active Member
    MalSikes
    Re: Can't boot up rev 12
    11-17-2010 05:03 PM in reply to: MalSikes
    I am strictly using DOS.
    I try to launch Autocad from the command prompt or the Dosshell and get the same results.
    Please use plain text.
    11-18-2010 08:27 AM in reply to: MalSikes
    On the odd chance that your acad.dcl file is corrupt, try this one. Don't forget there may be two instances, one in the acad directory and one in the support directory. Replace them both.
    Gne
    Active Member
    MalSikes
    11-18-2010 09:04 AM in reply to: MalSikes
    The computer loads into a program called Point and Shoot. From there I can goto the DOSSHELL, Windows, or other sub directories and programs.
    11-18-2010 09:41 AM in reply to: MalSikes
    Download a Dos 6.22 boot disk here .... ...
    http://www.bootdisk.com/bootdisk.htm
    Use it to boot your computer and see if Autocad will then run.
    Gene
    Active Member
    MalSikes
    11-18-2010 11:48 AM in reply to: MalSikes
    I boot up on DOS onto a program called Point and Shoot which allows me to choose Dosshell, Windows, Autocad etc.
    Active Member
    MalSikes
    11-18-2010 11:52 AM in reply to: easymike299
    Thanks. I'll give them a try and post the results.
    11-18-2010 12:11 PM in reply to: MalSikes
    What I'm suggesting is that you not use Point and Shoot but rather boot with a Dos 6.22 boot disk and run autocad from there.
    If you are not successful then I'm out of ideas.
    Gene
    Active Member
    MalSikes
    11-19-2010 12:52 PM in reply to: MalSikes
    EUREKA  I've done it. Thanks for all your help Gene. When I set up the computer to run Autocad I changed monitors. Everything worked fine on the monitor but I couldn't boot up Autocad. I remembered it had a monitor configuration on setup but thought they were the same. Just to confirm that was not the problem I installed my old monitor and auto cad came up just fine.
    Now I can get back to drawing. Thanks Again
    Mal
    11-19-2010 04:02 PM in reply to: MalSikes
    All's well that ends well.
    Gene
    11-26-2010 11:28 AM in reply to: easymike299
    It's possible to access R12 for Dos through a window in Win3.1
    I can post instructions if anyone  is interested.
    Gene
