AutoCAD R12/R13/R14 Archive
Member
Message 1 of 8 (85 Views)
autocad text window
85 Views, 7 Replies
02-26-2001 10:45 AM
Is there a way to prevent the text window opening every time I open a drawing
*Lincoln, Tracy W.
Message 2 of 8 (85 Views)
Re: autocad text window
02-26-2001 10:51 AM in reply to: beardedad
What "Text Window" are you referring to?
Tracy W. Lincoln
Assistant Moderator, Autodesk Discussion Groups
http://discussion.autodesk.com
beardedad wrote in message ...
Member
Message 3 of 8 (85 Views)
Re:
02-28-2001 09:20 AM in reply to: beardedad
Tracy,
When a drwing opens there is a window that opens that has autocad text window at the top of it. It has the same information that the lines at the bottom of the screen.
*Lincoln, Tracy W.
Message 4 of 8 (85 Views)
Re:
02-28-2001 10:08 PM in reply to: beardedad
Strange...
What does F2 do?
Can you dock this window?
Please DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Member
Message 5 of 8 (85 Views)
Re:
03-01-2001 11:21 AM in reply to: beardedad
when you press F2 it puts the text window screen behind the drawing screen. I do not know how to dock a window. Is theere a setup that I can fix this. One of the other draftman said that he clicks in the drawing window to get rid of it. But I thought ther was a way so that it did not come up at all
*Lincoln, Tracy W.
Message 6 of 8 (85 Views)
Re:
03-05-2001 12:31 AM in reply to: beardedad
Are there two command areas showing on the screen?
What does it say on the title bar? AutoCAD Text Window - drawing.dwg or
AutoCAD - Command Line - drawing.dwg?
Usually there is one docked at the bottom (default is three lines) and
hitting F2 brings up a resizable text screen (aka: command history or
flip screen) hitting F2 closes it, clicking on the X in the upper
right-hand corner closes it. If there is no X then your command prompt
is floating and you need to click and hold on the blue title bar and
drag it slowly to the bottom of the screen. As soon as you cursor hits
the edge the area will resize (goes wider) let go.
Tracy W. Lincoln
Member
Message 7 of 8 (85 Views)
Re:
03-06-2001 11:04 AM in reply to: beardedad
It shaas AutoCad Test Window on the title bar. What I would like to find out is if there is a way that this screen does not come on every time I open a new drawing. At one time it did not come on, but all of a sudden it started coming on every time I opened up a new drawing file.
*Lincoln, Tracy W.
Message 8 of 8 (85 Views)
Re:
03-06-2001 12:15 PM in reply to: beardedad
Dunno?
F2 or 'TEXTSCR makes it appear... maybe you (or someone
else) has it being called or redefined.
Tracy W. Lincoln
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
