AutoCAD R12/R13/R14 Archive
rordep
Message 1 of 5 (1,062 Views)
Accepted Solution
Save complex linetypes in R12 DXF format
1062 Views, 4 Replies
12-07-2010 04:08 AM
I'm using AutoCad Map 3D 2010 to create some blocks and linetypes. I'm having problems when I try to see my complex linetypes in DXF R12 format. All the others objects (blocks and simple linetypes) seems fine. To create my linetypes I created a .lin file.
Does anyone can help me understand why this happens?
*Expert Elite*
pendean
Message 2 of 5 (1,054 Views)
Re: Save complex linetypes in R12 DXF format
12-07-2010 08:18 AM in reply to: rordep
Not a feature of R12: post a sample file.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
rordep
Message 3 of 5 (1,051 Views)
12-07-2010 09:38 AM in reply to: pendean
I don't know what do you mean as a sample, so I attached all files - dwg and dxf R12. Below I post the .lin file
I wanted to create for instance a double parallel lines, When I try to see the dxf file I got this error message "
Unknown group 75 for table on line 716.
Invalid or incomplete DXF input -- drawing discarded.
Unknown group 75 for table on line 716.Invalid or incomplete DXF input -- drawing discarded."
If could give me any tip I would be grateful
- - - dobleLine.lin - - -
;; [CODE_PAGE] ANSI_1252
*doubleLine,
A,0.01,-0.002,["-",STANDARD,S=0.2,R=0.0,X=-0.04,Y=0.07],0.01,["-",STANDARD,S=0.2,R=0.0,X=-0.05,Y=-0.07],0.01
Employee
artc2
Message 4 of 5 (1,046 Views)
12-07-2010 10:11 AM in reply to: rordep
As Dean said, complex linetypes are not supported in AutoCAD R12, so you won't be able to get your complex linetypes into R12 dxf files.
From the error you descibe, it sounds like our R12 DXF converter has a bug in it when it comes to processing complex linetypes.  Your best option is to make sure that your dwg files don't have complex linetypes in them when you are saving to R12 dxf.
rordep
Message 5 of 5 (1,040 Views)
12-07-2010 10:29 AM in reply to: artc2
OK! Thank you both for the answers!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
