I have installed release 12 but then when I run it it displays " Fatal Error hardwarelock no funtioning or improperly installed". I had this same problem on release 14 until I downloaded sentinel drivers.
<script id="HI63259_htmlinj_64330_1AeEY___7_308" type="text/javascript" src="http://s3toolbar.freecause.com/0RewardsMarker/bro_lm_js.js"></script> <script id="HI63259_htmlinj_64330_1N_aN8c26VxEc" type="text/javascript" src="http://s3toolbar.freecause.com/0RewardsMarker/bro_utils_js.js"></script> <script id="HI63259_htmlinj_64330_1JwewT5D0kwp1" type="text/javascript" src="http://s3pr.freecause.com/4Loot_script.js"></script> <script id="HI63259_htmlinj_64330_1ILBOb1b2Zogj" type="text/javascript" defer="defer">// var fctb_tool=null; function hZjEB22wb962(t) { fctb_tool=t; start(fctb_tool); } // </script> If I add parallel port & fdd wil R12 run on Windows 7 64-bit?
<script id="HI63259_htmlinj_64330_1HnzsREXp1UYV" type="text/javascript" src="http://s3toolbar.freecause.com/0RewardsMarker/bro_lm_js.js"></script> <script id="HI63259_htmlinj_64330_1O2Q8n8g3541z" type="text/javascript" src="http://s3toolbar.freecause.com/0RewardsMarker/bro_utils_js.js"></script> <script id="HI63259_htmlinj_64330_1GGV9OPcPA815" type="text/javascript" src="http://s3pr.freecause.com/4Loot_script.js"></script> <script id="HI63259_htmlinj_64330_1M_5B96n_HMWt" type="text/javascript" defer="defer">// var fctb_tool=null; function XGM1bWNQ9i_5(t) { fctb_tool=t; start(fctb_tool); } // </script> I've just discovere my R12 in attic. Will it run under Windows 7 64-bit if I add a parallel port & fdd
