AutoCAD R12/R13/R14 Archive (Read Only)
Installing and Running AutoCAD R14 on Windows XP Professional
3 REPLIES 3
1384 Views, 3 Replies
Can someone please help me out with getting this program to run on Windows XP Professional.
That is if it is possible...
If it is not possible, what AutoCAD will we need to upgrade to?
Thank you for you time...
Any help would be appreciated.
3 REPLIES 3
It WILL run, but is not supported. It will install normally, just make sure you have administrator rights. For some "official" verbiage.... http://www.autodesk.com/us/xp_compatibility.htm
"Iceman" wrote in message news:f1159cb.-1@WebX.maYIadrTaRb...
We can not install it: although the install from the deployment point runs
without error, when autocad starts, it does not find the network license and
exits.
Installing in exactly the same way on NT4 works like a charm: autocad finds
the license server immediately, gets its token and starts. With XP, it
doesn't even call on the license server: I have the ADLM at maximum
verbosity and it does not even log a packet from that host.
Is it doable ?
R.K. McSwain a écrit dans le message ...
XP Professional.
Fredric,
You might try looking through the NETWORK discussion group:
NETWORK
news://discussion.autodesk.com/autodesk.autocad.network
http://discussion.autodesk.com/WebX?14@@.ee77eff
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
> exits.
> Is it doable ?
