AutoCAD R12/R13/R14 Archive
New Member
rlgross
Message 1 of 3 (925 Views)
Fatal Error Message AutoCad14 Unhandled Access Violation Exception 61e50eh
925 Views, 2 Replies
02-02-2012 10:50 AM
Fatal Error Message AutoCad 14
I tried to configure and add a digitizing board and digitizer a Geni" 4 button
I choose a Summagraphics MicroGrod V.1.1
The digitizer wouldn't wrk so I ended AutoCad. When I restarted it I got the fal error. I uninstalled aninstalled Auto Cad 14 and still get the same erroe
Product Support
zalant
Message 2 of 3 (919 Views)
Re: Fatal Error Message AutoCad14 Unhandled Access Violation Exception 61e50eh
02-02-2012 11:25 AM in reply to: rlgross
Back in 1998 there was a Development write-up about this issue, but it was fixed in AutoCAD 2000.  There was no patch developed for R14 to correct the behavior.  Step 1 of the listed "Steps to reproduce" was to install the digitizer.  Therefore, if you were to try uninstalling the digitizer driver and any related software, that might get you back in business (with AutoCAD).  Also, Step 4 was to turn off the digitizer, so perhaps having it on would eliminate the problem.  If there is no actual On/Off switch on the digitizer (I don't know if there is), substitue unplug/plug in for the on/off operations.
Failing all of the above, uninstall AutoCAD again and specify a different installation folder when you reinstall.  For example, if the default directory is C:\Program FIles\AutoCAD, tell it that you want to install into the C:\Program Files\AutoCAD-R14 folder.  It might help to create the empty folder prior to going back through the reinstall.
Please post back here any results you have (good or bad).
Zac Travis
New Member
rlgross
Message 3 of 3 (916 Views)
02-02-2012 11:36 AM in reply to: rlgross
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
