AutoCAD R12/R13/R14 Archive (Read Only)
Exporting Single Layer DXFs in R12 Format
5 REPLIES 5
1417 Views, 5 Replies
We work with a range of machines that can read single layer DXF files in R12 format.
However, we start with DWG or DXF files from Customers that are multilayer, and although we reduce the polygon info to a single layer, when we check the exported DXF there are normally 4 layers.
we always seem to see 4 layers, even when Customers export in R12 format for us.
This means that we can receive a 200k file with only 20K data, and we have to use a text editor to remove the first three layers.
We assume that there is a better way to ensure that Autocad does not output three unwanted layers which are very large and contain no useful data.
Can anyone help.
Please note that the required data are always 2D polygons.
5 REPLIES 5
Patchy
Freeze or turn off the layers not needed, then when dxfout, use Options as shown and select only the objects you need.
in reply to: Patchy
This does not seem to work.
Even when a single layer is selected, the file still contains multiple SECTIONS and dummy LAYERS. Depending on source, there are various differences. Mostly there are 4 sections of which only the last has useful information. This is all we need.
0
SECTION
2
ENTITIES
0
LINE
8
APS_GEOMETRY
10
508.000
11
508.000
20
117.000
21
10.000
0
LINE
8
APS_GEOMETRY
10
508.000
11
10.000
20
10.000
21
10.000
0
LINE
8
APS_GEOMETRY
10
10.000
11
10.000
20
10.000
21
117.000
0
ARC
8
APS_GEOMETRY
10
319.340
20
128.772
40
309.391
50
101.210
51
182.264
0
ARC
8
APS_GEOMETRY
10
199.043
20
128.772
40
309.390
50
357.736
51
78.790
0
ENDSEC
0
EOF
 Can you help us get to this point automatically. I'm getting fed up with text editing!
Thanks.
pendean
Unless this Old-School solution is not old enough for your AutoCAD version, turning FILEDIA off then starting DXFOUT command give you the option to SELECT OBJECTS, which allows you to limit what gets exported to DXF.
Another option: WBLOCK your layers to single DWG files and DXFOUT those new files.
All the above can be automated with lisp, scripts etc.
in reply to: pendean
Option 2 does not work. Already tried it. Leaves dummy layers in the file.
Tried option 1. Not a lot of difference to Option 2.
We can pull in a working DXF in the latest Autocad 2010 version, then save it again it gets substantially larger. Surely there must be a way of doing this without writing an application. We only use AutoCAD for the task of conversion.
If we have to, we would have to write a standalone routine that :
1. Finds the first LINE or ARC command in the file by seeking sequentially.
2. Seeks in reverse to the first layer command found.
3. Extracts the layer in its enirety.
4. Tops and tails and export.
This assumes that LINEs and ARCS are in only one layer.
Has anyone tried this within AutoCAD? We need an application that works with most recent versions of AutoCAD.
pendean
