We need to put the text into ESRI's ArcView. ArcView doesn't accept
ArcText -- only Text. We have several Acad drawings that have used ArcText
for presentations to clients. Since the drawings have already been drawn,
it would be nice to NOT to have to redo all the text in ArcView which would
add hours or days to the task.
So, I ask again, is there a way to explode the ArcText so the individual
letters
will remain in the exact position as they do before they are exploded?
Thank you
Wade Nederveld
Tracy Lincoln wrote in message
news:67D87F81CF021616AB59C155E9FD8FBA@in.WebX.SaUCah8kaAW...
> I guess my questions would be, why don't you use ARCTEXT to edit the text?
> What are the end results that you are trying to achieve?
> Tracy W. Lincoln
> ACI - Porter and Chester Institute - ATC - CT, USA
> Autodesk Learning and Training Moderator - AutoCAD Training Specialist
> Assistant Moderator, Autodesk Discussion Groups
> Wade Nederveld wrote in message ...
> >... Or at least the ArcText doesn't explode as expected.
> >When we use the bonus tool (Autocad 14.01) ArcText to align text around
an
> >arc)
> >and then explode the text, the text is backwards sometimes.
> >If I have an arc that bows up (the midpoint of the arc is above the 2 end
> >points)
> >and I add ArcText to the outside (top) of the arc, then explode the text,
> >the text
> >reads fine.
> > D E
> > C F
> >here the arc is below
> > B G
> >the text
> > A
H
> >If I have an arc that bows down (the midpoint of the arc is below the 2
end
> >points)
> >and add ArcText to the outside (bottom) of the arc, then explode, the
text
> >stays on
> >the outside, but its backwards.
> > A
> >H
> >This is what B
> >G here the arc is
> >it looks like ----------> C F
> >above the text
> >before exploding D E
> >After exploding, the text is still under the arc, but the letters are are
> >upside down.
> >To fix, we have to either mirror each letter along a line that is tangent
> to
> >the arc
> >at the text insertion of each letter, or mirror all the text at once
(which
> >will make
> >the text bow up (like it does in the top example) and move each letter
down
> >so that the text bows down.
> >Is there any way around this, so we don't have to adjust each letter to
get
> >the
> >desired effect? What am I missing here?
> >Any help would be greatly appreciated. Thank you.
> >Wade Nederveld
