AutoCAD R12/R13/R14 Archive (Read Only)
Error in open .dxf files
1 REPLY 1
mkyip
2068 Views, 1 Reply
A user here face problem in opening the .dxf files.
The original .dwg file can open/edit/save, but after convert it to .dxf file, the .dxf file cannot be opened and error message shown as below:
Error in BLOCK_RECORD Table
Invalid symbol table record name: "" on line 3840.
Invalid or incomplete DXF input -- drawing discarded.
1 REPLY 1
in reply to: mkyip
MKYIP,
This has been covered quite a few times in this very same
discussion group, the problem usually occurs when trying to BIND
an XREF. Pan down through the posts...
(hint: look for a post from Cook, Peter dated: 06/07/2001
and read the replies) or go to
http://discussion.autodesk.com and use the Search function
with a keyword of XREF.
Please DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln - Use the links below
Assistant Moderator, Autodesk Discussion Groups
Product Support: http://support.autodesk.com/
Knowledgebase: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Discussion Groups: http://discussion.autodesk.com
> below:
