AutoCAD R12/R13/R14 Archive
Patchy
Message 11 of 23 (1,096 Views)
Re: Downloading problems for 3rd party hatch patterns.
02-08-2011 08:30 PM in reply to: Patchy
Keep them separate, right on :manwink:, why do people edit the acad.pgp ?
*Pro
Modman_4
Message 12 of 23 (1,090 Views)
02-09-2011 05:18 AM in reply to: Patchy
OP what happens if you type OPTIONS on the command line?
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
pendean
Message 13 of 23 (1,084 Views)
02-09-2011 09:48 AM in reply to: Patchy
>>>...Who doesn't back up regularly?...<<<
Good one :smileyhappy:
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
pendean
Message 14 of 23 (1,085 Views)
02-09-2011 09:50 AM in reply to: Patchy
If the program offered another choice it would be used instead: you can't fancy-talk out of this, there is no correct or wrong way, just better ways and harder ways of doing things.
Patchy
Message 15 of 23 (1,080 Views)
02-09-2011 10:57 AM in reply to: Patchy
:smileyvery-happy: :smileyvery-happy: :smileyvery-happy:
kenrmer
Message 16 of 23 (1,078 Views)
02-09-2011 11:16 AM in reply to: Patchy
With ACLT 98 when typing "OPTIONS" on the command line, reply is "UNKNOWN COMMAND"`.
kenrmer
Message 17 of 23 (1,074 Views)
02-09-2011 11:55 AM in reply to: Patchy
Patchy, as requested here is an attachment with the Culture Stone Drystack hatch pattern installed in the Bhatch file. Saved it as a txt file. The cs_drystack is loaded after the last predefined hatch pattern ZIGZAG. Remember, I'm running ACLT98. I tried typing "options' in the command line and the response is "Command Not Found". When I go to Bhatch from the pull down tab I get the predefined patterns only, nothing in user-defined nor custom. When I click on custom, the custom pattern box becomes active with the last used predefined default pattern name still visible but....greyed out in the box just above. When I type in "cs_drystack"  into the custom box, the response is "unknown pattern name".
Patchy
Message 18 of 23 (1,072 Views)
02-09-2011 12:07 PM in reply to: Patchy
Everything looks good, except you forgot to put a ; (semicolon) at the last line of the file.
Just put one ;  by itslef and it should work
Like this:
45,34.826,21.8,27.0910285542,27.0910285542,0.54182,-53.6402371084
135,4.5592,23.715,27.0910285542,27.0910285542,0.54182,-53.6402371084
45,27.968,30.995,27.0910285542,27.0910285542,0.54182,-53.6402371084
0,27.547,1.4942,0,38.3125,1.9539,-36.3586
kenrmer
Message 19 of 23 (1,063 Views)
02-09-2011 02:14 PM in reply to: Patchy
Ok, added the semi-colon after the last line. Saved it, closed down, rebooted, reopened a dwg file, and...nothing changed. Rechcecked the aclt.pat file and the semi-colon is still there. No cs_drystack hatch pattern. Nothing in the custom category, nor predefined nor user-defined. Tried typing in "cs_drystack" in the custom pattern...reply is "no known pattern".
I even took out the space between the last predefined hatch pattern and the cs_drystack hatch pattern...no change.
This is the only copy of the AutoCAD LT98 on this computer, so it can't be due to multiple  programs.
I signed up with Culture Stone support last Friday. Still waiitng for administrator approval to sign in. Maybe they have an answer.
Patchy
Message 20 of 23 (1,060 Views)
02-09-2011 02:35 PM in reply to: kenrmer
Do this for me, at the command line type in:
(findfile "aclt.pat")           with the brackets like that, what does it prompt after you hit enter.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
