AutoCAD R12/R13/R14 Archive (Read Only)
Dimensioning in 3d
1 REPLY 1
472 Views, 1 Reply
Dimensioning in 3d
I am dimensioning a 3d object and I want to know if I am doing this properly.  I add the dimensions in model space.  For each view that needs to be dimensioned I create a layer for the dimensions of that view and I freeze the dimensions of all the other views.  I also need to create a new coordinate system for the dimensions of each view.  This is because the dimensions only can be drawn in the xy plane.  I cannot use the coordinate system which is easily created for each view by just selecting UCS-->View because that may put some of the dimensions inside the body of the object I am drawing and then when I use the Hide function some of the dimensions, or parts of them, are not visible.  Thus, I must create a new coordinate system for the dimensions of each view (that I need to dimension) for which the origin is located one or two units in front of the object I am drawing.  It just seems like a cumbersome and unduly complicated system to add dimensions and I would think that AutoCAD would have a simpler and/or more automated way of performing such a basic function.  Am I missing something?  Is there a shortcut or an easier way to do this?
1 REPLY 1
The essence of the question is: Do other people also create (as I am doing) both a new layer and a new coordinate system for each view that needs to be dimensioned?
