AutoCAD R12/R13/R14 Archive
*Grant, Brianne
Message 1 of 5 (37 Views)
Binding XREFS
37 Views, 4 Replies
02-14-2001 02:28 AM
I can't seem to be able to Bind my XREF to my project. It keep
regenerating itself. Anyone have any suggestions?
thank you,
brianne
*Lincoln, Tracy W.
Message 2 of 5 (37 Views)
Re: Binding XREFS
02-14-2001 03:29 AM in reply to: *Grant, Brianne
Were these drawings ever opened in AutoCAD 2000 or 2000i and Saved As
R14s?
Try going to:
http://support01.autodesk.com/ViewDownload.asp
put in "bind" or "bindptch.arx" and select Go
downloading bindptch.arx and read bindptch.txt
Also going to:
http://support01.autodesk.com/ViewAnswerworks.asp
and asking questions sometimes helps.
Lastly, You also might want to go to http://discussion.autodesk.com and
select AutoCAD and use BIND or XREF as a keyword to see other
discussions on the topic, as there are also unnamed objects that can
also cause problems. Good luck.
Please DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator, Autodesk Discussion Groups
> thank you,
> brianne
*Clark, Jeff
Message 3 of 5 (37 Views)
Re: Binding XREFS
02-14-2001 03:33 AM in reply to: *Grant, Brianne
If the drawing you are trying to bind was created in Acad 2000, you'll get
an invalid message. You'll need to download "bindptch.arx" from Autodesk's
website.
*Jim
Message 4 of 5 (37 Views)
Re:
02-15-2001 08:07 AM in reply to: *Grant, Brianne
Have any of you experienced:
;; Warning: Invalid block name "" found.
;; ...dwg needs recovery.
;; xref loaded.
If a dwg (say x.dwg) has this particular 'invalid "" block name' - it causes
the parent file (some file that xrefs x.dwg) to crash when attempting to
detach x.dwg.
any clues?
Thanks in advance for any help.
"Jeff Clark" wrote in message
news:50FBD358ADC05FE27322FC3811EC4C27@in.WebX.maYIadrTaRb...
> website.
*Lincoln, Tracy W.
Message 5 of 5 (37 Views)
Re:
02-15-2001 10:06 PM in reply to: *Grant, Brianne
Have you tried BLANKBLK.DVB from the Free Stuff section of
http://www.dotsoft.com?
Tracy W. Lincoln
> ;; xref loaded.
> detach x.dwg.
> any clues?
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
