AutoCAD - Português
AutoCAD - Português
Responder
New Member
thiscimoraes
Envios: 1
Mensagem 1 de 10 (7.559 Exibições)
Problema para instalar no Windows 8
7559 Exibições, 9 Respostas
04-25-2013 07:00 AM
Estou tentando instalar a versão estudantil que baixei no site da Autodesk, mas a instalação sempre falha antes de iniciar.
No instalation log file aparece o seguinte:
2013/4/23:21:45:18 Thiscianne Haroldo === Setup started on Haroldo by Thiscianne ===
2013/4/23:21:45:18 Thiscianne Haroldo Path_Length: 155
2013/4/23:21:45:18 Thiscianne Haroldo Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/23:21:45:18 Thiscianne Haroldo Launch
2013/4/23:21:45:18 Thiscianne Haroldo CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/23:21:45:18 Thiscianne Haroldo Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AI7481.tmp
2013/4/23:21:49:03 Thiscianne Haroldo === Setup ended ===
2013/4/23:21:45:19 Thiscianne Haroldo === Setup started on Haroldo by Thiscianne ===
2013/4/23:21:45:19 Thiscianne Haroldo Path_Length: 155
2013/4/23:21:45:19 Thiscianne Haroldo Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AI7481.tmp
2013/4/23:21:45:19 Thiscianne Haroldo Launch
2013/4/23:21:46:30 Thiscianne Haroldo Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/23:21:49:02 Thiscianne Haroldo Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/23:21:49:02 Thiscianne Haroldo Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AI7481.tmp\Setup\AcSetup.dll
2013/4/23:21:49:02 Thiscianne Haroldo Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/23:21:49:02 Thiscianne Haroldo PageOpen LaunchDialog
2013/4/23:21:50:51 Thiscianne Haroldo PageOpen LicenseDialog
2013/4/23:21:50:51 Thiscianne Haroldo PageOpen ProductInfoDialog
2013/4/23:21:50:51 Thiscianne Haroldo PageOpen ProductSelectionDialog2
2013/4/23:21:51:34 Thiscianne Haroldo PageOpen FullProgressDialog
2013/4/23:21:51:35 Thiscianne Haroldo Download Play DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:00:13 Thiscianne Haroldo Download Error DOTNET4LANG <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:00:13 Thiscianne Haroldo Download Error DOTNET4LANG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:00:21 Thiscianne Haroldo Download User Resume DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:31:59 Thiscianne Haroldo Download Complete DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:31:59 Thiscianne Haroldo Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/23:22:32:05 Thiscianne Haroldo Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/23:22:32:08 Thiscianne Haroldo PageOpen InstallCompleteDialog
2013/4/23:22:32:42 Thiscianne Haroldo === Setup ended ===
2013/4/23:22:34:03 Thiscianne Haroldo === Setup started on Haroldo by Thiscianne ===
2013/4/23:22:34:03 Thiscianne Haroldo Path_Length: 155
2013/4/23:22:34:03 Thiscianne Haroldo Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/23:22:34:03 Thiscianne Haroldo Launch
2013/4/23:22:34:03 Thiscianne Haroldo CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/23:22:34:03 Thiscianne Haroldo Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AI1733.tmp
2013/4/23:22:34:05 Thiscianne Haroldo === Setup ended ===
2013/4/23:22:34:04 Thiscianne Haroldo Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/23:22:34:04 Thiscianne Haroldo Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AI1733.tmp\Setup\AcSetup.dll
2013/4/23:22:34:04 Thiscianne Haroldo Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/23:22:34:04 Thiscianne Haroldo PageOpen LaunchDialog
2013/4/23:22:34:08 Thiscianne Haroldo PageOpen LicenseDialog
2013/4/23:22:34:08 Thiscianne Haroldo PageOpen ProductInfoDialog
2013/4/23:22:34:08 Thiscianne Haroldo PageOpen ProductSelectionDialog2
2013/4/23:22:34:34 Thiscianne Haroldo PageOpen FullProgressDialog
2013/4/23:22:34:35 Thiscianne Haroldo Download Skipped DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:34:35 Thiscianne Haroldo Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/23:22:34:40 Thiscianne Haroldo Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/23:22:34:41 Thiscianne Haroldo PageOpen InstallCompleteDialog
2013/4/23:22:35:06 Thiscianne Haroldo === Setup ended ===
2013/4/24:11:18:56 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/24:11:18:56 Thiscianne HAROLDO Path_Length: 155
2013/4/24:11:18:56 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/24:11:18:56 Thiscianne HAROLDO Launch
2013/4/24:11:18:56 Thiscianne HAROLDO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/24:11:18:56 Thiscianne HAROLDO Setup Windows update reboot is pending
2013/4/24:11:19:15 Thiscianne HAROLDO Setup Autodesk® AutoCAD® 2014 Will restart automatically.
2013/4/24:11:19:15 Thiscianne HAROLDO === Setup ended ===
2013/4/24:11:39:07 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/24:11:39:07 Thiscianne HAROLDO Path_Length: 155
2013/4/24:11:39:07 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/24:11:39:07 Thiscianne HAROLDO Launch
2013/4/24:11:39:07 Thiscianne HAROLDO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/24:11:39:07 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AID1AD.tmp
2013/4/24:11:39:22 Thiscianne HAROLDO === Setup ended ===
2013/4/24:11:39:10 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/24:11:39:10 Thiscianne HAROLDO Path_Length: 155
2013/4/24:11:39:10 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AID1AD.tmp
2013/4/24:11:39:10 Thiscianne HAROLDO Launch
2013/4/24:11:39:11 Thiscianne HAROLDO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/24:11:39:12 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AID1AD.tmp\Setup\AcSetup.dll
2013/4/24:11:39:12 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/24:11:39:12 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/24:11:39:23 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/24:11:39:23 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/24:11:39:23 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/24:11:39:29 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/24:11:39:29 Thiscianne HAROLDO Download Skipped DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/24:11:39:29 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/24:11:39:36 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/24:11:39:38 Thiscianne HAROLDO PageOpen InstallCompleteDialog
2013/4/24:11:40:17 Thiscianne HAROLDO === Setup ended ===
2013/4/25:00:46:54 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:00:46:54 Thiscianne HAROLDO Path_Length: 155
2013/4/25:00:46:54 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/25:00:46:54 Thiscianne HAROLDO Launch
2013/4/25:00:46:54 Thiscianne HAROLDO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/25:00:46:54 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIFAFC.tmp
2013/4/25:00:46:57 Thiscianne HAROLDO === Setup ended ===
2013/4/25:00:46:55 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:00:46:55 Thiscianne HAROLDO Path_Length: 155
2013/4/25:00:46:55 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIFAFC.tmp
2013/4/25:00:46:55 Thiscianne HAROLDO Launch
2013/4/25:00:46:55 Thiscianne HAROLDO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/25:00:46:56 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AIFAFC.tmp\Setup\AcSetup.dll
2013/4/25:00:46:56 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/25:00:46:56 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/25:00:47:02 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/25:00:47:02 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/25:00:47:02 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/25:00:47:06 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/25:00:47:06 Thiscianne HAROLDO Download Skipped DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/25:00:47:06 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/25:00:47:13 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/25:00:47:15 Thiscianne HAROLDO PageOpen InstallCompleteDialog
2013/4/25:00:47:21 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:48:50 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:14:48:50 Thiscianne HAROLDO Path_Length: 155
2013/4/25:14:48:50 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/4/25:14:48:50 Thiscianne HAROLDO Launch
2013/4/25:14:48:50 Thiscianne HAROLDO CommandLine
2013/4/25:14:48:50 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIB216.tmp
2013/4/25:14:48:54 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:48:52 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:14:48:52 Thiscianne HAROLDO Path_Length: 155
2013/4/25:14:48:52 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIB216.tmp
2013/4/25:14:48:52 Thiscianne HAROLDO Launch
2013/4/25:14:48:52 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AIB216.tmp\Setup\AcSetup.dll
2013/4/25:14:48:52 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/25:14:48:54 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/25:14:48:56 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/25:14:49:00 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/25:14:49:33 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/25:14:49:36 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/25:14:49:36 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/25:14:49:43 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/25:14:49:43 Thiscianne HAROLDO PageOpen InstallCompleteDialog
2013/4/25:14:50:46 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:51:12 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:14:51:12 Thiscianne HAROLDO Path_Length: 155
2013/4/25:14:51:12 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/4/25:14:51:12 Thiscianne HAROLDO Launch
2013/4/25:14:51:12 Thiscianne HAROLDO CommandLine
2013/4/25:14:51:12 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AID9E8.tmp
2013/4/25:14:51:15 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:51:13 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AID9E8.tmp\Setup\AcSetup.dll
2013/4/25:14:51:13 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/25:14:51:15 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/25:14:51:17 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/25:14:51:20 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/25:14:51:39 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/25:14:51:43 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/25:14:51:43 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/25:14:51:50 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
Alguém sabe como ajudar?
*Expert Elite*
f_santana
Envios: 533
Mensagem 2 de 10 (7.550 Exibições)
Re: Problema para instalar no Windows 8
04-25-2013 12:27 PM em resposta a: thiscimoraes
quando foi que voce fez o download da sua versão educacional?
estou perguntando porque a informação que esta no site da Autodesk é está
AutoCAD 2014 and AutoCAD LT 2014 (current release)
OS32-bit64-bit
Windows® 8Standard, Enterprise, ProfessionalStandard, Enterprise, Professional
Windows® 7Enterprise, Ultimate, Professional, Home PremiumEnterprise, Ultimate, Professional, Home Premium
Windows® XPProfessional, Home Edition (SP3 or later)Professional x64 Edition (SP2 or later)
já tentou fazer um novo download?
não sei como funciona, os estudantes tiveram a liberação para download antes dos outros clientes
tenta baixar a versão trial e utilizar nela o numero serial que foi enviado para você pelo Student Autodesk.
- Marque a resposta que resolveu o seu problema como solução, isso ajuda os outros usuários em suas buscas;
- Utilize a ferramenta de pesquisa do fórum, a sua duvida já pode estar respondida.
Fábio Santana Send Fabio Santana a Private Message | Arquiteto | CAD/BIM Manager | fdscon.wordpress.com
Colaborador da Comunidade de Usuários Autodesk Brasil
New Member
lucasnavalconstrucao
Envios: 1
Mensagem 3 de 10 (7.523 Exibições)
04-28-2013 07:09 PM em resposta a: thiscimoraes
Estou com o mesmo problema, nem o 2013 e 2014 funcionam, interrompem a instalaçao antes de começar.
Valued Contributor
we.weslley
Envios: 73
Mensagem 4 de 10 (7.509 Exibições)
04-29-2013 11:58 AM em resposta a: lucasnavalconstrucao
Primeiro de tudo desistala todos os aplicativos da Autodesk e apos ter feito isso ve se tem instalado no seu computador o Directx http://www.baixaki.com.br/download/directx-end-user-runtime-web-installer.htm
Apos ter feito isso re instale novamente  AutoCAD..
Att
Obs.:
- Não se esqueça de marcar a resposta que resolveu o seu problema como solução, isso ajuda os outros usuários em suas buscas;
- Sempre utilize a ferramenta de pesquisa do fórum, a sua duvida já pode estar respondida.
New Member
juliosilvafh
Envios: 1
Mensagem 5 de 10 (7.486 Exibições)
04-29-2013 08:50 PM em resposta a: thiscimoraes
Salve uma cópia do arquivo setup.ini em um outro diretório, edite o arquivo contente na pasta de instalação, localize a palavra net, por exemplo, e todas as vezes que ele aparecer em uma linha que comece com a palavra " pre-requisitos", delete a linha toda, a linha deve aparecer umas 3 ou 4 vezes no arquivo, basta que remova-as e só instalar novamente.
Aqui funcionou. Em anexo o arquivo com a linha a ser apagada.
Member
KGB_Black
Envios: 3
Mensagem 6 de 10 (7.399 Exibições)
05-04-2013 11:44 PM em resposta a: f_santana
f_santana escreveu:
OS 32-bit 64-bitWindows® 8 Standard, Enterprise, Professional Standard, Enterprise, Professional Windows® 7 Enterprise, Ultimate, Professional, Home Premium Enterprise, Ultimate, Professional, Home Premium Windows® XP Professional, Home Edition (SP3 or later) Professional x64 Edition (SP2 or later)
olá!
instalei a ultima versao free trial do autocad 2014 no meu win 8 e tive o mesmo problema das versoes anteriores!
qdo  inicio o cad ele da 2 msg de erro na abertura dele! é como se ele nao gravasse q ja fez a abertura inicial e sempre abre como se fosse a primeira vez!
ele da a seguinte mensagem!
Exception in acvmtools.crx ARX Command
Unhandled exception C0000005 (Access Violation Reading 0x0000) at address 2B0B2B60h
2x a mesma mensagem se dou OK nas 2 ele abre o cad!
e se nao bastasse isso ele ainda trava depois de um tempo de uso! cerca de uns 10 min ou ate menos!
aconteceu isso comigo com as versoes trial do 2012, 2013 e 2014!
alguem  ja conseguiu resolver isso?
obrigado!
*Expert Elite*
f_santana
Envios: 533
Mensagem 7 de 10 (7.382 Exibições)
05-06-2013 08:22 AM em resposta a: KGB_Black
KGB_Black os seus drives de video estão atualizados?
Qual a sua placa de video?
Member
KGB_Black
Envios: 3
Mensagem 8 de 10 (7.365 Exibições)
[ Editado ]
05-07-2013 02:31 PM em resposta a: f_santana
Minha placa de video é uma
Mobile Intel(R) 965 Express Chipset Family
e esta com o driver atualizado
pois tive q atualizar para poder funcionar a barra transparente do win 8! hehe
o interessante é q eu tinha a versao 2012 instalada no win 7 antes e nao tinha nenhum problema!
qdo tentei por a mesma versao e no caso depois testar outras ne tive o problema! mas com o win 8!
agradeço a ajuda!
*Expert Elite*
f_santana
Envios: 533
Mensagem 9 de 10 (7.359 Exibições)
05-07-2013 03:03 PM em resposta a: KGB_Black
fiz uma busca sobre este codigo de erro na base de dados da Autodesk
http://usa.autodesk.com/adsk/servlet/ps?siteID=123112&id=21208844&linkID=21208795
e ele sempre esta associado ao DRIVES "inadequados/não certificados" para a utilização do programas
no caso fiz uma outra busca para verificar a placa intel recomentada/certificada é só encontrei esta
http://usa.autodesk.com/adsk/servlet/syscert/card?siteID=123112&catID=18254205&id=18844534&product=8...
voce mesmo pode fazer este tipo de busca aqui
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Member
KGB_Black
Envios: 3
Mensagem 10 de 10 (7.340 Exibições)
05-08-2013 07:40 AM em resposta a: f_santana
Agradeço ao seu tempo dispensado a tentar me ajudar!
Porém resolvi o problema de uma forma simples e q depois fiquei pensando pq nao pensei nisso antes! hehehe
o arquivo da msg era o AcVMTools.crx e junto com ele tem tambem o AcVMTools.arx dentro da pasta do cad dentro de arquivos de programas!
Fiz uma copia deles! e depois apaguei eles da pasta do cad!
iniciou o cad sem problema nenhum!
nao travou nada!
esta funcionando 100%!
nao e a alternativa recomendada! sei disso mas resolveu!
mais uma vez obrigado pela ajuda!
e por mim fica a dica pra quem tiver este problema basta apagar estes 2 arquivos que o problema some junto com eles! hehehe
abraço!
You are not logged in.
Faça login no seu perfil de acesso para perguntar e responder questões, compartilhar ideias e muito mais. Não se inscreveu ainda? Registrar
Comunicados
Need installation help?
Pergunte a Comunidade
