Comunidade
AutoCAD - Português
Bem vindo ao Forum de AutoCAD da Autodesk. Compartilhe seu conhecimento, faça perguntas e explore os tópicos mais populares de AutoCAD.
cancelar
Mostrando resultados para
Mostrar  apenas  | Pesquisar então
Você quer dizer:
Problema para instalar no Windows 8
11 RESPOSTAS 11
Responder
Mensagem 1 de 12
thiscimoraes
10870 Exibições, 11 Respostas
Estou tentando instalar a versão estudantil que baixei no site da Autodesk, mas a instalação sempre falha antes de iniciar.
No instalation log file aparece o seguinte:
2013/4/23:21:45:18 Thiscianne Haroldo === Setup started on Haroldo by Thiscianne ===
2013/4/23:21:45:18 Thiscianne Haroldo Path_Length: 155
2013/4/23:21:45:18 Thiscianne Haroldo Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/23:21:45:18 Thiscianne Haroldo Launch
2013/4/23:21:45:18 Thiscianne Haroldo CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/23:21:45:18 Thiscianne Haroldo Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AI7481.tmp
2013/4/23:21:49:03 Thiscianne Haroldo === Setup ended ===
2013/4/23:21:45:19 Thiscianne Haroldo === Setup started on Haroldo by Thiscianne ===
2013/4/23:21:45:19 Thiscianne Haroldo Path_Length: 155
2013/4/23:21:45:19 Thiscianne Haroldo Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AI7481.tmp
2013/4/23:21:45:19 Thiscianne Haroldo Launch
2013/4/23:21:46:30 Thiscianne Haroldo Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/23:21:49:02 Thiscianne Haroldo Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/23:21:49:02 Thiscianne Haroldo Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AI7481.tmp\Setup\AcSetup.dll
2013/4/23:21:49:02 Thiscianne Haroldo Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/23:21:49:02 Thiscianne Haroldo PageOpen LaunchDialog
2013/4/23:21:50:51 Thiscianne Haroldo PageOpen LicenseDialog
2013/4/23:21:50:51 Thiscianne Haroldo PageOpen ProductInfoDialog
2013/4/23:21:50:51 Thiscianne Haroldo PageOpen ProductSelectionDialog2
2013/4/23:21:51:34 Thiscianne Haroldo PageOpen FullProgressDialog
2013/4/23:21:51:35 Thiscianne Haroldo Download Play DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:00:13 Thiscianne Haroldo Download Error DOTNET4LANG <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:00:13 Thiscianne Haroldo Download Error DOTNET4LANG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:00:21 Thiscianne Haroldo Download User Resume DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:31:59 Thiscianne Haroldo Download Complete DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:31:59 Thiscianne Haroldo Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/23:22:32:05 Thiscianne Haroldo Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/23:22:32:08 Thiscianne Haroldo PageOpen InstallCompleteDialog
2013/4/23:22:32:42 Thiscianne Haroldo === Setup ended ===
2013/4/23:22:34:03 Thiscianne Haroldo === Setup started on Haroldo by Thiscianne ===
2013/4/23:22:34:03 Thiscianne Haroldo Path_Length: 155
2013/4/23:22:34:03 Thiscianne Haroldo Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/23:22:34:03 Thiscianne Haroldo Launch
2013/4/23:22:34:03 Thiscianne Haroldo CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/23:22:34:03 Thiscianne Haroldo Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AI1733.tmp
2013/4/23:22:34:05 Thiscianne Haroldo === Setup ended ===
2013/4/23:22:34:04 Thiscianne Haroldo Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/23:22:34:04 Thiscianne Haroldo Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AI1733.tmp\Setup\AcSetup.dll
2013/4/23:22:34:04 Thiscianne Haroldo Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/23:22:34:04 Thiscianne Haroldo PageOpen LaunchDialog
2013/4/23:22:34:08 Thiscianne Haroldo PageOpen LicenseDialog
2013/4/23:22:34:08 Thiscianne Haroldo PageOpen ProductInfoDialog
2013/4/23:22:34:08 Thiscianne Haroldo PageOpen ProductSelectionDialog2
2013/4/23:22:34:34 Thiscianne Haroldo PageOpen FullProgressDialog
2013/4/23:22:34:35 Thiscianne Haroldo Download Skipped DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/23:22:34:35 Thiscianne Haroldo Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/23:22:34:40 Thiscianne Haroldo Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/23:22:34:41 Thiscianne Haroldo PageOpen InstallCompleteDialog
2013/4/23:22:35:06 Thiscianne Haroldo === Setup ended ===
2013/4/24:11:18:56 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/24:11:18:56 Thiscianne HAROLDO Path_Length: 155
2013/4/24:11:18:56 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/24:11:18:56 Thiscianne HAROLDO Launch
2013/4/24:11:18:56 Thiscianne HAROLDO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/24:11:18:56 Thiscianne HAROLDO Setup Windows update reboot is pending
2013/4/24:11:19:15 Thiscianne HAROLDO Setup Autodesk® AutoCAD® 2014 Will restart automatically.
2013/4/24:11:19:15 Thiscianne HAROLDO === Setup ended ===
2013/4/24:11:39:07 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/24:11:39:07 Thiscianne HAROLDO Path_Length: 155
2013/4/24:11:39:07 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/24:11:39:07 Thiscianne HAROLDO Launch
2013/4/24:11:39:07 Thiscianne HAROLDO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/24:11:39:07 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AID1AD.tmp
2013/4/24:11:39:22 Thiscianne HAROLDO === Setup ended ===
2013/4/24:11:39:10 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/24:11:39:10 Thiscianne HAROLDO Path_Length: 155
2013/4/24:11:39:10 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AID1AD.tmp
2013/4/24:11:39:10 Thiscianne HAROLDO Launch
2013/4/24:11:39:11 Thiscianne HAROLDO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/24:11:39:12 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AID1AD.tmp\Setup\AcSetup.dll
2013/4/24:11:39:12 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/24:11:39:12 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/24:11:39:23 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/24:11:39:23 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/24:11:39:23 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/24:11:39:29 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/24:11:39:29 Thiscianne HAROLDO Download Skipped DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/24:11:39:29 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/24:11:39:36 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/24:11:39:38 Thiscianne HAROLDO PageOpen InstallCompleteDialog
2013/4/24:11:40:17 Thiscianne HAROLDO === Setup ended ===
2013/4/25:00:46:54 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:00:46:54 Thiscianne HAROLDO Path_Length: 155
2013/4/25:00:46:54 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/4/25:00:46:54 Thiscianne HAROLDO Launch
2013/4/25:00:46:54 Thiscianne HAROLDO CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u..." /SN 900-33593210 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/4/25:00:46:54 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIFAFC.tmp
2013/4/25:00:46:57 Thiscianne HAROLDO === Setup ended ===
2013/4/25:00:46:55 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:00:46:55 Thiscianne HAROLDO Path_Length: 155
2013/4/25:00:46:55 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIFAFC.tmp
2013/4/25:00:46:55 Thiscianne HAROLDO Launch
2013/4/25:00:46:55 Thiscianne HAROLDO Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/4/25:00:46:56 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AIFAFC.tmp\Setup\AcSetup.dll
2013/4/25:00:46:56 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/25:00:46:56 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/25:00:47:02 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/25:00:47:02 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/25:00:47:02 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/25:00:47:06 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/25:00:47:06 Thiscianne HAROLDO Download Skipped DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/4/25:00:47:06 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/25:00:47:13 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/25:00:47:15 Thiscianne HAROLDO PageOpen InstallCompleteDialog
2013/4/25:00:47:21 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:48:50 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:14:48:50 Thiscianne HAROLDO Path_Length: 155
2013/4/25:14:48:50 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/4/25:14:48:50 Thiscianne HAROLDO Launch
2013/4/25:14:48:50 Thiscianne HAROLDO CommandLine
2013/4/25:14:48:50 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIB216.tmp
2013/4/25:14:48:54 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:48:52 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:14:48:52 Thiscianne HAROLDO Path_Length: 155
2013/4/25:14:48:52 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AIB216.tmp
2013/4/25:14:48:52 Thiscianne HAROLDO Launch
2013/4/25:14:48:52 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AIB216.tmp\Setup\AcSetup.dll
2013/4/25:14:48:52 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/25:14:48:54 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/25:14:48:56 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/25:14:49:00 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/25:14:49:33 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/25:14:49:36 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/25:14:49:36 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/25:14:49:43 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/4/25:14:49:43 Thiscianne HAROLDO PageOpen InstallCompleteDialog
2013/4/25:14:50:46 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:51:12 Thiscianne HAROLDO === Setup started on HAROLDO by Thiscianne ===
2013/4/25:14:51:12 Thiscianne HAROLDO Path_Length: 155
2013/4/25:14:51:12 Thiscianne HAROLDO Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/4/25:14:51:12 Thiscianne HAROLDO Launch
2013/4/25:14:51:12 Thiscianne HAROLDO CommandLine
2013/4/25:14:51:12 Thiscianne HAROLDO Current Directory C:\Users\THISCI~1\AppData\Local\Temp\_AID9E8.tmp
2013/4/25:14:51:15 Thiscianne HAROLDO === Setup ended ===
2013/4/25:14:51:13 Thiscianne HAROLDO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\THISCI~1\AppData\Local\Temp\_AID9E8.tmp\Setup\AcSetup.dll
2013/4/25:14:51:13 Thiscianne HAROLDO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/25:14:51:15 Thiscianne HAROLDO PageOpen LaunchDialog
2013/4/25:14:51:17 Thiscianne HAROLDO PageOpen LicenseDialog
2013/4/25:14:51:20 Thiscianne HAROLDO PageOpen ProductInfoDialog
2013/4/25:14:51:39 Thiscianne HAROLDO PageOpen ProductSelectionDialog2
2013/4/25:14:51:43 Thiscianne HAROLDO PageOpen FullProgressDialog
2013/4/25:14:51:43 Thiscianne HAROLDO Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/25:14:51:50 Thiscianne HAROLDO Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
Alguém sabe como ajudar?
11 RESPOSTAS 11
Mensagem 2 de 12
f_santana
em resposta a: thiscimoraes
quando foi que voce fez o download da sua versão educacional?
estou perguntando porque a informação que esta no site da Autodesk é está
AutoCAD 2014 and AutoCAD LT 2014 (current release)
OS32-bit64-bit
Windows® 8Standard, Enterprise, ProfessionalStandard, Enterprise, Professional
Windows® 7Enterprise, Ultimate, Professional, Home PremiumEnterprise, Ultimate, Professional, Home Premium
Windows® XPProfessional, Home Edition (SP3 or later)Professional x64 Edition (SP2 or later)
já tentou fazer um novo download?
não sei como funciona, os estudantes tiveram a liberação para download antes dos outros clientes
tenta baixar a versão trial e utilizar nela o numero serial que foi enviado para você pelo Student Autodesk.
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Fábio Santana
Architect | CAD/BIM Manager
Mensagem 3 de 12
Estou com o mesmo problema, nem o 2013 e 2014 funcionam, interrompem a instalaçao antes de começar.
Mensagem 4 de 12
we.weslley
em resposta a: Anonymous
Primeiro de tudo desistala todos os aplicativos da Autodesk e apos ter feito isso ve se tem instalado no seu computador o Directx http://www.baixaki.com.br/download/directx-end-user-runtime-web-installer.htm
Apos ter feito isso re instale novamente  AutoCAD..
Att
Obs.:
- Não se esqueça de marcar a resposta que resolveu o seu problema como solução, isso ajuda os outros usuários em suas buscas;
- Sempre utilize a ferramenta de pesquisa do fórum, a sua duvida já pode estar respondida.
Mensagem 5 de 12
juliosilvafh
Salve uma cópia do arquivo setup.ini em um outro diretório, edite o arquivo contente na pasta de instalação, localize a palavra net, por exemplo, e todas as vezes que ele aparecer em uma linha que comece com a palavra " pre-requisitos", delete a linha toda, a linha deve aparecer umas 3 ou 4 vezes no arquivo, basta que remova-as e só instalar novamente.
Aqui funcionou. Em anexo o arquivo com a linha a ser apagada.
Mensagem 6 de 12
KGB_Black
em resposta a: f_santana
f_santana escreveu:
OS 32-bit 64-bitWindows® 8 Standard, Enterprise, Professional Standard, Enterprise, Professional Windows® 7 Enterprise, Ultimate, Professional, Home Premium Enterprise, Ultimate, Professional, Home Premium Windows® XP Professional, Home Edition (SP3 or later) Professional x64 Edition (SP2 or later)
olá!
instalei a ultima versao free trial do autocad 2014 no meu win 8 e tive o mesmo problema das versoes anteriores!
qdo  inicio o cad ele da 2 msg de erro na abertura dele! é como se ele nao gravasse q ja fez a abertura inicial e sempre abre como se fosse a primeira vez!
ele da a seguinte mensagem!
Exception in acvmtools.crx ARX Command
Unhandled exception C0000005 (Access Violation Reading 0x0000) at address 2B0B2B60h
2x a mesma mensagem se dou OK nas 2 ele abre o cad!
e se nao bastasse isso ele ainda trava depois de um tempo de uso! cerca de uns 10 min ou ate menos!
aconteceu isso comigo com as versoes trial do 2012, 2013 e 2014!
alguem  ja conseguiu resolver isso?
obrigado!
Mensagem 7 de 12
f_santana
em resposta a: KGB_Black
KGB_Black os seus drives de video estão atualizados?
Qual a sua placa de video?
Fábio Santana
Mensagem 8 de 12
KGB_Black
Minha placa de video é uma
Mobile Intel(R) 965 Express Chipset Family
e esta com o driver atualizado
pois tive q atualizar para poder funcionar a barra transparente do win 8! hehe
o interessante é q eu tinha a versao 2012 instalada no win 7 antes e nao tinha nenhum problema!
qdo tentei por a mesma versao e no caso depois testar outras ne tive o problema! mas com o win 8!
agradeço a ajuda!
Mensagem 9 de 12
f_santana
fiz uma busca sobre este codigo de erro na base de dados da Autodesk
http://usa.autodesk.com/adsk/servlet/ps?siteID=123112&id=21208844&linkID=21208795
e ele sempre esta associado ao DRIVES "inadequados/não certificados" para a utilização do programas
no caso fiz uma outra busca para verificar a placa intel recomentada/certificada é só encontrei esta
http://usa.autodesk.com/adsk/servlet/syscert/card?siteID=123112&catID=18254205&id=18844534&product=8...
voce mesmo pode fazer este tipo de busca aqui
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Fábio Santana
Mensagem 10 de 12
KGB_Black
Agradeço ao seu tempo dispensado a tentar me ajudar!
Porém resolvi o problema de uma forma simples e q depois fiquei pensando pq nao pensei nisso antes! hehehe
o arquivo da msg era o AcVMTools.crx e junto com ele tem tambem o AcVMTools.arx dentro da pasta do cad dentro de arquivos de programas!
Fiz uma copia deles! e depois apaguei eles da pasta do cad!
iniciou o cad sem problema nenhum!
nao travou nada!
esta funcionando 100%!
nao e a alternativa recomendada! sei disso mas resolveu!
mais uma vez obrigado pela ajuda!
e por mim fica a dica pra quem tiver este problema basta apagar estes 2 arquivos que o problema some junto com eles! hehehe
abraço!
Mensagem 11 de 12
aluisflores
Excluir os dois arquivos também deu certo pra mim!!
Mensagem 12 de 12
f_santana
Estes dois arquivos fazem parte dos controles de vídeo do AutoCAD.
geralmente eles dão problema quando algum drive da placa de vídeo esta com problema ou muito desatualizado.
solucionar os problemas com a sua placa de vídeo teria sido uma melhor solução
Fábio Santana
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
Postar nos fóruns
