• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    why devided 2 iso drawings? pipe & half coupling
    149 Views, 2 Replies
    02-13-2013 06:52 PM
    Hi, I'm June
    i'm usuing 2013 version.
    I was connected pipe & half coupling.(image attached No.1)
    But If i make a iso drawing, it devided 2 drawings. (image attached No.2)
    (I checked the Force one sheet option)
    Why devided 2 drawings.. Please give me advise..
    Please use plain text.
    Distinguished Contributor
    Arun_Kumar_K
    Re: why devided 2 iso drawings? pipe & half coupling
    02-14-2013 06:56 AM in reply to: junhokim
    Coupling not connected, that is the reason. right click on the main pipe and select connected line number, you will observe coupling without highlighting.
    Employee
    TomislavGolubovic
    02-14-2013 11:36 AM in reply to: Arun_Kumar_K
    correct. I would also check in your spec that the branch table is populated properly, otherwise any branches won't connect and you will get the drip symbol at each connection.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
