• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    unrecognized chinese character in exported Excel file when created ISO
    247 Views, 3 Replies
    02-15-2012 07:43 PM
    As you know,when we create ISO,we can export relevant Infor to excel file just like BOM,cut piece and so on.
    But if there is any chinese character in it,these chinese character will display as unrecognized in the excel file.
    Version:smileytongue:lant3D 2012 64 bit
    it seams that it happens in 2012 and the future version 2013.
    Any solution?
    thanks and regards
    Please use plain text.
    Employee
    VickyADSK
    Re: unrecognized chinese character in exported Excel file when created ISO
    02-16-2012 10:48 PM in reply to: 19820415
    Command: PLANTPCFUNICODE > ON
    Then create iso. the loc language should be displayed correctly in table reports.
    Vicky
    Autodesk Plant Solutions
    Valued Contributor
    02-19-2012 09:31 PM in reply to: VickyADSK
    Thank you Vicky.
    But it still doesn't solve this problem.
    when we set PLANTPCFUNICODE as ON,it do make some change with the output excel file.
    but the chinese character is still display as unrecognized.
    pls see attached pictures.
    hope there is some better solution.
    thanks in advance.
    Rong
    Employee
    VickyADSK
    03-05-2012 11:19 PM in reply to: 19820415
    Thank you Rong.
    We're looking into the limitation.
    Vicky
