08:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I use my Osnaps, I use shift+right click, then use a single hot key (as underlined when the menu opens).
Since installing SP1 for 2013, I can only use the hot key once (after a short while I can use a hot key once again), next time I try to use a hot key, it just closes the menu and redirects the key entry into the command prompt.
Any thoughts on what is going on here? BTW, this does seem to be just in Autocad/ plant as excel still "hot keys" normally.
Thanks, Rob
