question regarding PID
M-BRF
M-BRF
good morning
I have a problem / question regarding PID
1 - insert a expasion join the TOOL - PID PIP / Fitting
2nd select with the mouse the expasion joint inserted,  click right mouse button and  Assing tag is  in gray which I can not put it I can only put it annotation
As I fix
Regards and thanks
I do not understand a lot of English and I helped with the google translator, perdor for errors
Dan.Scales
By default the Expansion Joint symbol is not a tagged component.
To change this you need to open the Project Setup and edit the symbol:
Hope this helps.
Dan
Dan Scales
M-BRF
gracias por tu ayuda.
me has salvado de un ataque de histeria de tantas pruebas e intentos y tocar por todos los lados ( ja ja)
best regards
Joaquin
