• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    gschimmi
    problem with flange connections
    217 Views, 5 Replies
    06-20-2012 12:57 AM
    Hello
    since yesterday I can not make flange connections between flanges, flanges and pipe, flanges to nozzles from equipment.
    Only from valves I can by using the plus-grip add flanges.
    That only occurs when I'm using my own piping class.
    I think I had not change anything. I only installed SP2 for Plant3D 2012.
    Any ideas?
    Guido
    Please use plain text.
    Product Support
    Re: problem with flange connections
    07-06-2012 08:52 AM in reply to: gschimmi
    Would you be willing to share a sample project with me so I can try to establish the cause of this issue?
    Dan
    Dan Scales
    Product Support Specialist
    Valued Contributor
    gschimmi
    07-08-2012 10:38 PM in reply to: DanScales
    Hi
    I think I found the problem. I have british (flanges) and metric parts. When I insert the parts one by one there is no problem. When I use auto-flange this error occurs when I use a flange with british units. The same flange with metric units works....
    Do you still need a sample project?
    Guido
    Product Support
    07-09-2012 01:52 AM in reply to: gschimmi
    You need to enable imperial to metric connections in the Project Setup:
    I hope this helps.
    Dan
    Dan Scales
    Valued Contributor
    gschimmi
    07-09-2012 02:44 AM in reply to: DanScales
    Hi
    it is enabled. The problem occurs only by auto-flange.
    Guido
    Active Member
    01-22-2013 01:26 AM in reply to: gschimmi
    I have the same problem when trying to insert metric valves into imperial pipe. The imperial to metric connection option is enables but autoflange does not work.
    If I manually add a single flange to the end of a pipe, I can add a metric valve, then manualy add a flange then continue routing. Alternatively I can add a flange pair in the center of a section of pipe that has been routed and add the valve between the two flanges.
    Does anyone know why autoflange does not work with imperial to metric connections?
