• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    plant 3d validation problem
    131 Views, 0 Replies
    11-14-2012 03:53 AM
    The case is as follows:
    - I have a p&id drawing that contains primary line with gate valve of 6" with tag ( 6"-P-CS150-1000 )
    - For 3d model i opened the p&id list and place both of pipe and gate valve
    at this moment everything is ok
    but when i change the line tag at p&id to ( 8"-P-CS150-1000 )
    THEN i make a validation process it gives an error for the valve size but doesn't give an error for the pipe
    which mean if i have a pipe without any fittings or valves with different property it will not give an error
    secondly when i changed the line tag at p&id to ( 8"-P-CS150-1000 ) the size of the pipe at 3d model remains 6" inch, so is there any way to match the changes at p&id to the 3d model
    thnx in advance
    Please use plain text.
