• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    pipe insultation not represented in orthoview P3D2013
    217 Views, 6 Replies
    01-28-2013 07:02 AM
    Hi
    question in the tittle
    is it a P3D  bugg or a misuse on my part ?
    Please use plain text.
    Employee
    Re: pipe insultation not represented in orthoview P3D2013
    01-28-2013 09:41 AM in reply to: SamScopeo
    It's not a bug, per se. The ortho feature doesn't show the insulation. Do you mind sharing an example of what you'd like to see with the insulation? It's on our list to implement, but one thing that's been slowing us down is lack of user examples of what's required.
    Most examples that I've seen include a short segment showing the insulation requirements of the pipe - kind of like the iso PP insulation symbol. This is possible now. What I've been hearing is that we need to show insulation on all pipes, but exactly what's needed, along with some example drawings would be useful for the software development team.
    Peter Quinn
    Senior Product Manager
    01-28-2013 11:19 AM in reply to: PeterQuinn
    Hi thanks,
    Ok not a bugg, I understand that it a missing in the function devellopment.
    A piping layout must show the apparent dimension. So the pipe with the insulation.
    This to check and see the real the volume / place take by the pipe in a area.
    An example can be made in model space choose a top view and hidden render
    Sam
    Active Contributor
    01-28-2013 12:24 PM in reply to: PeterQuinn
    Here's an example of how we show it, one LB pipe and one SB pipe.  We don't always use the elbow version, but it's nice to have sometimes.
    Distinguished Contributor
    Arun_Kumar_K
    01-30-2013 07:45 AM in reply to: EricNyh
    A good image attached. it will be nice to get insulation symbol at every elbows and one insulation symbol between two elbows.
    Also we require flow direction symbol in Orthographic.
    Product Support
    gersteb
    02-01-2013 01:41 AM in reply to: Arun_Kumar_K
    Thank you all for your suggestions how it shall look like. Those advices will be part of the implementation of this enhancement request.
    Bernd Gerstenberger
    Senior Support Specialist
    Product Support
    02-18-2013 09:51 AM in reply to: gersteb
    Hi
    I agree with Eric and THERMAX
    It's the practices of the profession
