• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    New Member
    pipe connection to equipment failed
    103 Views, 2 Replies
    01-25-2013 07:32 PM
    When i try to connect my equipment to a pipe, the program send me a error saying that can't recognize the pipe/connection.
    How can i make the connection between the pipe and the equipment?
    i'm using the plant 3d 2013.
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: pipe connection to equipment failed
    01-27-2013 02:49 PM in reply to: js.gomes
    Are the values matching on the nozzle to the pipe spec you are working on? Check those figures first.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    New Member
    01-27-2013 03:49 PM in reply to: TomislavGolubovic
    Thanks. You solve me half of my problem.
    The problem persist when i try to conect two equipments. That's my real problem. For example, i need to connect a reactor to a filter and when i try to do that, autocad send me a error.
