• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    parametric or script based valves
    213 Views, 1 Replies
    09-16-2012 07:21 AM
    for the food industry we use multiport valves. It is possible to rotate the ports of the valve in every direction. For example when I have a valve with two ports I want to place a valve and set the right angle. the top port is placed at 90 degr. and the bottom port at 45 degr.
    Is it possible to make one part where I can rotate the ports?
    I know Bentley Autoplant can do this since 2004.
    Please use plain text.
    Distinguished Contributor
    Arun_Kumar_K
    Re: parametric or script based valves
    10-04-2012 08:41 AM in reply to: snijdam
    Plant3d does not have the option to custom model the valve with 2 ports in xy direction and 3rd port in zdirection. I have already requested this option to Autodesk.
