• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    Active Member
    kmankov
    nooby
    205 Views, 4 Replies
    04-30-2012 07:44 AM
    Is there any tutorial that shows how to create project including demonstration how to draw example elements - like riser to valves to tank ... I could not find what to draw first - PID or Model. I did start a project, but I have no idea how to actually draw it correctly. What is best philosophy or best technics that should be used?
    Please use plain text.
    Employee
    Re: nooby
    05-01-2012 10:30 AM in reply to: kmankov
    Try the links posted here: http://autocad.autodesk.com/?nd=plant_online_help2
    Pat Jenakanandhini
    Product Manager
    Plant Solutions - AEC
    Employee
    TomislavGolubovic
    Re: nooby
    05-01-2012 03:19 PM in reply to: kmankov
    A P&ID is usually the controlling document for the Plant. It defines the equipment, pipe sizes, specs, service and other variables that are required to build the plant. It lists all the valves, instrumentation everything. A Process Engineer is usually the person who might sketch this, then have it drawn by a P&ID designer.
    From this, you create a model. The P&ID elements (lines and in-line fittings) can be drag-n-dropped from the P&ID into the model. As for layout, thats entirely dependant on the site, structure, etc. After this, you then get into doing Ortho drawings and Isometrics for production.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Active Member
    kmankov
    Re: nooby
    05-01-2012 03:31 PM in reply to: TomislavGolubovic
    Thank you. How to draw a line at 45deg in PID? (riser)
    Employee
    TomislavGolubovic
    Re: nooby
    05-01-2012 04:41 PM in reply to: kmankov
    Right click on the project in Project Manager, and select Properties.
    From this new window, expand the "P&ID DWG Settings" then go to "Line Settings" and look for the tick box down the bottom marked "Create ortho schematic lines"
    Tomislav Golubovic
