• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    need to convert a iges file (valve) into a "useable" valve on ttemplate
    155 Views, 4 Replies
    08-22-2012 02:02 PM
    I have imported a iges file into my project in AutoCAD Plant 3D, but if I convert it to a piece of equipment or a block then it slows down the drawing REALLY BAD! I would take time and draw each valve I have, which are manual and acuated valves ranging in different sizes from 1" up to 4".
    I have not used the spec editor much and really get lost in creating my own valves at this point. I already have these 11 or 12 valves in the drawing but are they are not solid objects and they are not compatiable with my piping.
    Can someone help me with the steps I need to take in converting what I have into workable piping componets...Please
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: need to convert a iges file (valve) into a "useable" valve on ttem
    08-22-2012 03:26 PM in reply to: chrishope12
    Have a look at the youtube channel in regards to editing catalogs and specs. There is also a video that shows how to make custom parts.
    I would personally put all these items into your own spec to use for future projects, rather than doing them one at a time when required.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Valued Mentor
    JohnHolder
    08-22-2012 05:49 PM in reply to: chrishope12
    Inventor Fusion can convert to DWG fairly easily, then when the model looks proper and in the correct format, block it and convert it.
    I have a bunch of former IGES files - butterfly valves, that I have converted this way and it works fine.
    John.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Member
    08-23-2012 06:38 AM in reply to: JohnHolder
    Thank you for the info. Now, I have created the dwg. file from the iges. through Inventor Fusion, which was really nice, but I now need to know how to make this dwg. valve work in spec editor.
    Do I make it a block? which if I do, then I can't snap flanges or pipe to it. What do I do to make this valve a useable valve or place it on a template?
    Valued Mentor
    JohnHolder
    08-23-2012 11:51 AM in reply to: chrishope12
    you create a block of your valve. Then use the command  <plantpartconvert> this will let you add your ports  Once you have this done, then it's into the spec editor.
    open your spec and catalog
    add it to your catalog and spec.
    Master Yoda.
