isometrics - wrong 'connected to'
Hi
in the isometric a connection to RHC41-BR.01 is shown, (see attachm.) but thats wrong! Its RHC10....
I've checked this in 3D!!!
Any ideas?
Guido
TomislavGolubovic
Can you post the model?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Yes, here it is
Oh, sorry, I have two models in two drawings (as built and new). When I select a line number for generating an isometric P3D makes isometrics from both models, not only from the open drawing. Right?
G
TomislavGolubovic
I have made the mating flange part of the header line number, and the connection shows fine. I have some concerns about the welds in the model, if they are of the proper line numbers.
But I would make the Northern Flange '41' and the Southern Flange '10' (for their line numbers).
Tomislav Golubovic
Autodesk, Inc.
I've checked all line parts (nicl. welds) and reffered them to the correct line numbers.
And it looks fine now.
Thank you.
