• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    daniel
    iso operator in bom
    316 Views, 7 Replies
    09-24-2012 04:38 PM
    is there a way to call up valve operator calls in the bom (bill of materieals) on iso's??
    great lengths to make different operator symbols but none are called in iso's!
    help!!
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: iso operator in bom
    09-26-2012 06:34 PM in reply to: daniel
    Can you be to send us a screenshot of your requirement. This would help to troubleshoot the issue better.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    Active Member
    daniel
    09-26-2012 08:48 PM in reply to: VinodBalasubramanian
    Here you go.
    I would like operator types for valves in the iso bill of materieals.
    (as the same valve has different operators attached to it)
    thanks
    daniel
    Product Support
    09-26-2012 09:06 PM in reply to: daniel
    Thanks for the screenshot. Your screenshot is confusing me. Do you want the actuators to be separate in the BOM or added to the valve body. Which one is your request ?
    Autodesk Support
    Autodesk, Inc.
    Active Member
    daniel
    09-26-2012 09:09 PM in reply to: VinodBalasubramanian
    Hello
    i'd pefer them to be scheduled seperatly
    thanks
    daniel
    Product Support
    09-26-2012 11:42 PM in reply to: daniel
    Actuators are not separated by Nominal Diameter but Valves are grouped under ND. Actuators are grouped by their sizes. You can turn off actuators in BOM but you can't show it in BOM separately at the moment.
    Autodesk Support
    Autodesk, Inc.
    Active Member
    daniel
    09-27-2012 01:13 PM in reply to: VinodBalasubramanian
    i cant turn them on in the bom, can you show me how???
    please.
    daniel
    Distinguished Contributor
    philip
    10-23-2012 12:46 PM in reply to: VinodBalasubramanian
    What we are trying to do is have the iso constructed from two SKEY's one a valve body & one an actuator (lever, wheel, geared etc) with one of the two these two options happing when iso is run
    1) have the valve display differently for each combination of valve body/actuator, not just lump all the same valve body togeather with no actuator type called
    2) have same valve bodies grouped togeather called with seperate BOM entry calls for actuators
