• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    TBoo
    iso border attributes
    168 Views, 3 Replies
    02-24-2012 01:04 PM
    I am having a hard time with the attribute justification in the iso border setup. Everything works pretty good just when I create the iso the border attributes are not in the place I put them such as center justified. Some are pushed over to the left a little bit which kinda creates a problem. If I double click the attribute and edit the justification to… lets say left the text moves and then select back to center, the text moves to the place where it should have been in the first place. It kinda makes that little tool useless to me. Could I may be doing something wrong? Is there a tutorial or something else out there somewhere?
    Please use plain text.
    Member
    Re: iso border attributes
    02-27-2012 06:26 PM in reply to: TBoo
    Apparantly its a bug, mine does the same, just grab everything, move it slightly and it seems to fix it.
    TBoo
    02-28-2012 12:25 PM in reply to: ian.whistler
    The only thing with that is if you edit the text it will go back where it was supposed to be. which is now further to the right than where you wanted it to go in the first place. An Autodesk personnel needs to look in to this little bug.
    ricardo.janesko
    04-23-2012 06:56 AM in reply to: TBoo
    Someone found a solution to this? In Plant 2013 this also happens.
