• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    how to get a pipe elevation once it is drawn
    308 Views, 2 Replies
    05-02-2012 06:10 AM
    i have no idea how to get an elevation of a pipe once it is drawn
    i already tried to selecte it go into its properties and try to see if there is an elevation data but there is none
    so need help guys
    thanks
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: how to get a pipe elevation once it is drawn
    05-02-2012 08:45 PM in reply to: syria89
    Pick the pipe and there is a grip that looks like a triangle (it'll be above the pipe, not under/beside it) and this, when picked, will let you change the elevation (TOP, COP and BOP). From there you can see what the EL is at.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    05-03-2012 07:58 AM in reply to: TomislavGolubovic
    i tried what u asked
    but the trinagle which is above is to change part
    the triangle which is below it is to change elevation but it will start from 0 then you add how much u wanna bring up or down
    but the only way i found as i show it in the pic attached it is to click on the middle blue square and see what is the coordinate in the buttom left of autocad window
    btw i am using autocad plant 3d 2013
