• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    diagonal lines in ortho views
    131 Views, 2 Replies
    01-15-2013 01:28 AM
    Is it possible to get rid of the diagonal lines in ortho views?
    I make walls in ASD and xref to a plant 3d modell, and make ortho views. Everything works fine except for the diagonal lines.
    Best regards
    Please use plain text.
    Valued Contributor
    Re: diagonal lines in ortho views
    01-15-2013 10:20 AM in reply to: hardell
    edit block..
    erase lines..
    done!
    01-15-2013 11:25 PM in reply to: batone79
    Thanks for the suggestion,
    the blocks are anonymous and are not possible to edit. you can of course exlode them and remove the lines, which i did. this is solution is not very convinient if you have many drawings. every time you make an update, the lines are there again. there must be a better way to get rid of the lines.
    //J
