• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    bad initialization of network paths P3D 2013
    328 Views, 9 Replies
    02-14-2013 12:40 AM
    Context :
    We work in network :
    - P3D projets,
    - project's specs
    - SharedContentFolder with catalogs
    are on our server.
    Description of observations
    At each (re)start of user's computer, when the user launchs P3D, the networks path are not seen as connected by P3D.(red crosses on network letters appear in P3D file browe window). And P3D is not able to find by itself any network file/folder
    However, in Windows file browser the network letters are correctly connected.
    After the user had browse in P3D file browser, the network letters become connected and P3D is able to find the files/folders
    See JPEG attached
    Consequences :
    - The launch of P3D is very very long : P3D try to find the path of the last project open, and it can't,
    - the PLANTCONTENTFOLDER is redirected to local path "C:\AutoCAD Plant 3D 2013 Content"
    - the user have to open the project manualy
    - the user have to redirect the PLANTCONTENTFOLDER  to server with the command PLANTMODIFYSHAREDCONTENTFOLDER
    Any solution is welcome ! Thanks
    Sam
    Please use plain text.
    Product Support
    Re: bad initialization of network paths P3D 2013
    02-15-2013 09:41 AM in reply to: SamScopeo
    What kind of drive is the network share? Is it a Windows box or some type of NAS drive?
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    02-15-2013 11:17 AM in reply to: DanScales
    I've had that problem too.  I found that if I opened the Drive in Windows Explorer before launching P3D it is able to find the drive.
    Ed
    02-18-2013 12:24 AM in reply to: DanScales
    Our drives are some SMB Windows 2008 R2 shared folder (on a dedicated file server).
    On user's computers it's deployed using GPO, as network drives (Windows 7).
    SamScopeo
    02-18-2013 12:27 AM in reply to: eadkins73
    Yes, I've figured that out too. But this is no solution. I can't tell users they have to open the drive before launch P3D.
    I'm looking for an automated solution :smileyhappy:
    SamScopeo
    Product Support
    02-26-2013 07:00 AM in reply to: SamScopeo
    If you map the drives manually without using GPO to do it does the issue occur?
    Dan
    Dan Scales
    Autodesk, Inc.
    02-27-2013 05:04 AM in reply to: DanScales
    Hi Dan
    I tried map the drives manually : same issue :-(
    Sam
    Product Support
    02-27-2013 05:51 AM in reply to: SamScopeo
    Hi Sam,
    I think the next thing to look at is permissions.
    If you assign the user full administrator permission does the same happen?
    Dan
    Dan Scales
    Autodesk, Inc.
    02-27-2013 07:08 AM in reply to: DanScales
    Hi Dan,
    I have already  full administrator permissions on my workstation
    Sam
    Product Support
    02-27-2013 09:09 AM in reply to: SamScopeo
    Hi Sam,
    If you open the project.xml files does the fileName and uncFileName path look correct?
    Dan
    Dan Scales
    Autodesk, Inc.
