AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Working with a project that's on the network
- Highlight
- Email to a Friend
- Report Inappropriate Content
I am having to work on a project that was started and is currently kept in its entirety on our network drive here at work. I need to be able to work from home every now and then and I don't have access to our network files and folders. I tried just copying the entire plant folder over to my C drive because that includes all the files that I am currently working with but I was unable to do certain things like cut new ortho views and a few other odd quirks.
Is there a "pack and go" style export feature for Plant 3D 2013 that I should be using to be able to work on a project located on the network from my C drive? I also don't want to run into any issues while syncing the files that I have worked on off the network with the files on the network to update for everyone else.
Re: Working with a project that's on the network
- Highlight
- Email to a Friend
Plant 3D does not have a "Pack and Go" feature. Just to verify, you did copy the entire project folder?
So, are you able to get into each Plant 3D drawing file and you are able to add and make changes with no problems? Is it just the ortho views and other odd quirks that you are experiencing?
Quentin Contreras
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
You might find also, that the project configuration calls up things like DWT files and borders from network locations, and because you're running off your C:\ now, that those paths won't be found.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
- Highlight
- Email to a Friend
To take the files with you is not a good idia , better an the only god way
access from home to your office , then there will be no problem
cw
- Highlight
- Email to a Friend
if you are taking the file home via a laptop you can make the directories of the project available off line so every time you disconnect your laptop from the system it will sync the files/paths etc onto you computer and back when you log back into the office system. (not tried it myself)
Betreff: Working with a project that's on the network
- Highlight
- Email to a Friend
so noboy know how P3D works , so why you are writhing ?
IT DOSENT WORK , just for the one how have a problem to hear .
not even Vault are able to handel it ( dosent mater what ADSK say )
if you take Files out of the Projekt or copy them an someone else work on the same file or made changes in the
config of the Projekt .... ITS GON
cw
( turn arond an shake the head )
