• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    daniel
    Re: Wish List AutoCAD Plant3D 2014
    09-24-2012 04:41 PM in reply to: ybogdanov
    a match line number & spec button..
    its slow to go to properties and change line numbers, when one exists already, plus its a pain when my line number list is in the hundreds.... scrolling through them all...ahhhhh!!!! help!
    daniel
    Please use plain text.
    Active Member
    10-04-2012 06:32 AM in reply to: ybogdanov
    I miss an "Explorer" for Piplins to finde fast pipline parts.
    *Expert Elite*
    dave.wolfe
    10-04-2012 07:15 AM in reply to: VTU-REl
    Use the data manager. In 2013 you can use the drop down at the bottom left to switch the view to by area, and then you can view line groups.  Click on the header row will select and zoom to the items even if they are in another drawing.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Active Member
    10-04-2012 08:07 AM in reply to: dave.wolfe
    Sorry I don´t know how.
    in my Datamanger 2012 German version is that not available.
    *Expert Elite*
    dave.wolfe
    10-04-2012 08:22 AM in reply to: VTU-REl
    For 2012, you have to go to  Project Setup > Plant 3D DWG Settings > Data Manager Configuration > Order by Area.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Member
    10-05-2012 09:00 AM in reply to: ybogdanov
    I´d like to have a annotation preview in ortho-drawings
    Distinguished Contributor
    PatrickByrne
    10-06-2012 01:43 AM in reply to: DanG...
    Annotate xref assemblies similar to Orthographic Views.
    We create our arrangement drawings by using xrefs of our steelwork and pipework models, these are very large and contain Prosteel objects. At this stage we will not be using Plant 3D orthographic views.
    It would be good if Plant 3D could do this by retrieving the line number, or tag information from the xref model and placing it in Paperspace. Similar to how CadWorx does it.
    PatrickByrne
    10-06-2012 01:44 AM in reply to: PatrickByrne
    Add expansion joints as a Plant 3D piping component, they are a common pipe line item. Presently I have to make a custom block for each size.
    PatrickByrne
    Re: e: Wish List AutoCAD Plant3D 2014
    10-06-2012 01:45 AM in reply to: PatrickByrne
    Isometric start point.
    I have mentioned this in an earlier post and the response from Autodesk support is it will be logged as an enhancement request.
    On our last project using CadWorx we had over 400 pipe models creating over 550 isometrics. I could open a piping assembly and batch create the isometrics, having the Isogenstartpoint set up on each model saved a lot of time and rework. This type of command should not be thought of as an enhancement but a necessary part of the program.
    PatrickByrne
    10-06-2012 03:37 AM in reply to: PatrickByrne
    Speed up Isometric creation. While it does work in the background this is not much help since you usually have the model finished and are waiting for the isometric to see that everything is correct.
