AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Wish List AutoCAD Plant3D 2014
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
a match line number & spec button..
its slow to go to properties and change line numbers, when one exists already, plus its a pain when my line number list is in the hundreds.... scrolling through them all...ahhhhh!!!! help!
daniel
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I miss an "Explorer" for Piplins to finde fast pipline parts.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Use the data manager. In 2013 you can use the drop down at the bottom left to switch the view to by area, and then you can view line groups. Click on the header row will select and zoom to the items even if they are in another drawing.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry I don´t know how.
in my Datamanger 2012 German version is that not available.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For 2012, you have to go to Project Setup > Plant 3D DWG Settings > Data Manager Configuration > Order by Area.
Isaiah 57:15
ECAD, Inc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I´d like to have a annotation preview in ortho-drawings
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Annotate xref assemblies similar to Orthographic Views.
We create our arrangement drawings by using xrefs of our steelwork and pipework models, these are very large and contain Prosteel objects. At this stage we will not be using Plant 3D orthographic views.
It would be good if Plant 3D could do this by retrieving the line number, or tag information from the xref model and placing it in Paperspace. Similar to how CadWorx does it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Add expansion joints as a Plant 3D piping component, they are a common pipe line item. Presently I have to make a custom block for each size.
Re: e: Wish List AutoCAD Plant3D 2014
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Isometric start point.
I have mentioned this in an earlier post and the response from Autodesk support is it will be logged as an enhancement request.
On our last project using CadWorx we had over 400 pipe models creating over 550 isometrics. I could open a piping assembly and batch create the isometrics, having the Isogenstartpoint set up on each model saved a lot of time and rework. This type of command should not be thought of as an enhancement but a necessary part of the program.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Speed up Isometric creation. While it does work in the background this is not much help since you usually have the model finished and are waiting for the isometric to see that everything is correct.
