• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    ybogdanov
    Re: Wish List AutoCAD Plant3D 2014
    05-20-2012 01:37 PM in reply to: ybogdanov
    - Create instruments in Spec Editor (the instrument Type is not avaibale for new components).
    - Any aplication for control all symbols (blocks) in the project. For substitute the parametric simbols to custom simbols in the final part of project. For create better presentation in Navisworks.
    - Automatic representation of insulation in isos of pipes.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Please use plain text.
    05-24-2012 06:14 AM in reply to: ybogdanov
    Vault integration please.
    Valued Mentor
    ybogdanov
    05-25-2012 02:20 PM in reply to: jeromefc
    - using metric units in metric project when is defined dimensions for custom imerial parts. - change height of rows in iso table. When is insert some column for "class/pn" this column is convert in doble row because the name of property is too but is necesarry to do that the height of row is couldn't depen of name of property, because t'he most important is value.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Active Contributor
    Jorgen1990
    05-29-2012 06:22 AM in reply to: ybogdanov
    I wish a better overall performance (less unexplainable errors). 2013 is already much better than 2012 was, but still some things are bad. For example, I regulary experience pipelines losing the data they have in Properties panel (Size, spec, material and so on) and their functionality (can't continue routing, can't insert components, can't lengthen). This is really annoying error. Sometimes a save and autocad restart helps, bus sometimes I just have to re-draw the whole pipeline. And I have run the "recover" on drawing.
    I added an explanatory screenshot to make it clear what I mean.
    Jörgen
    Valued Mentor
    ybogdanov
    05-29-2012 06:33 AM in reply to: Jorgen1990
    Jörgen
    Don't use recover option in Plant3D because is posible to lose link with database (in same objects of the drawing).
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Active Contributor
    Jorgen1990
    06-05-2012 04:12 AM in reply to: ybogdanov
    Thanks for the advice! But the problem occured BEFORE I ran the "recover" on drawing, so this can't be the reason... and also, sometimes when I want to open a dwg in Plant 3D, the programs tells me there are errors in dwg and I have to recover before I can open the dwg.
    sorry for the offtopic!
    Jörgen
    Active Contributor
    Jorgen1990
    06-07-2012 07:37 AM in reply to: ybogdanov
    Also a wish for Plant 3D 2014: "Quick ortho" command for testing ortho creation (so that program doesn't add the ortho dwg into the Project Manager, similiarily to Quick Iso).
    Employee
    06-07-2012 11:31 AM in reply to: Jorgen1990
    Quick ortho. That's an interesting idea.
    Peter Quinn
    Senior Product Manager
    dave.wolfe
    06-07-2012 02:06 PM in reply to: PeterQuinn
    I'm sure Jorgen meant to add that he wanted more features available for configuring orthos before a quick ortho was developed...right?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Mentor
    ybogdanov
    06-07-2012 11:55 PM in reply to: dave.wolfe
    The ortho now is the alhilles heel of Plant3D. There are many futures wich is posible to copy from AutoCAD MEP. Because it's just what need our customers.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
