AutoCAD Plant 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Weld dots
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
351 Views, 2 Replies
06-08-2011 06:15 AM
Which utility has "Weld dots" ?
In the help :
"Weld dots
Diameter
Sets the size of weld dots and other connector objects (for example: a bolt set, or a threaded joint marker). In the model, welded joints are connector objects that display as a solid circle.
NoteThe weld dot diameter sets the display size of all connector objects. "
But if I change the value in the model don't change anything.
Re: Weld dots
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-08-2011 04:52 PM in reply to:
bogdanov.y
Try REGEN3 or closing and re-opening the DWG.
Also be sure to check the value of PLANTWELDDISPLAY.
Jorge Lopez
Software Architect
Autodesk Plant Solutions
Re: Weld dots
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-09-2011 03:30 AM in reply to:
lopezjo
using the command PLANTWELDDISPLAY and set "ON" this is the view:
Thank you very much!
