• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    Arun_Kumar_K
    Wafer Type valve without Gaskets
    353 Views, 5 Replies
    11-24-2012 08:15 AM
     We need to model the Wafer type valve without gaskets as the wafer type valve is supplied along with lining (no need of gasket required in this condition), how to do it in Plant3d.
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: Wafer Type valve without Gaskets
    11-26-2012 08:24 PM in reply to: Arun_Kumar_K
    make an end type, i use WFL (wafer lined)
    set joint properties for FL to WFL to not have gasket
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Arun_Kumar_K
    11-27-2012 04:20 AM in reply to: Rich.O.3d
    Checked in Piping end connection, i couldn't find the end connection named WFL. Can u add a snapshot?
    Valued Mentor
    Rich.O.3d
    11-27-2012 05:32 AM in reply to: Arun_Kumar_K
    you have to add the endtype...type PLANTENDCODES, you will be able to add new endtypes
    once you have added it, then you go to project props and set up the joint type
    CAD Management 101:
    Member
    atul_0775
    12-03-2012 03:01 AM in reply to: Rich.O.3d
    dear sir
    i am done all step in P3D but still wafer type valve come with gasket so pls. sugges me as soon as possible.
    Valued Mentor
    Rich.O.3d
    05-04-2013 05:13 PM in reply to: atul_0775
    your simple joints WaferFlanged and WaferWafer are conflicting, you havent actualy defined a joint for a flange to connect to a wafer.
    your WaferFlanged joint should have 'End 1' as WFL and 'End 2' as FL
    CAD Management 101:
