• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    attila_vallyon
    Valves on wrong layer
    263 Views, 5 Replies
    03-19-2012 04:14 AM
    Hello!
    Sometimes the valves go on wrong layer. Even if I change the layer of the valve after I isolate that layer the valve disappears. If it would be on different layer. I have to use BEDIT command to edit the valve block, delete the 3D model an replace a new one with 0 layer.
    The 3D solid of a valve has to be on 0 layer within the block. But the P3D assign different layer within the block to that 3D solid.
    Is it a bug?
    Can it be fixed?
    Attila Vallyon
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Valves on wrong layer
    03-19-2012 06:40 AM in reply to: attila_vallyon
    You can access layer settings for Plant 3D by going to PROJECTSETUP, Plant 3D DWG Settings > Layer and Color Settings.
    Have you set up your layers like you want them to be through this dialog?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    attila_vallyon
    03-19-2012 08:15 AM in reply to: dave.wolfe
    Actually I turned off this feature a long time ago.
    I made those custom made valves with custom geometry. Maybe the problem was with the 3D solids. I changed all line properties of the solid (color, linetype, lineweight, material) to ByBlock. Hopefully I won't have this kind of problem anymore.
    Attila Vallyon
    Valued Contributor
    milic.srdjan
    03-20-2012 04:09 AM in reply to: attila_vallyon
    We have the same problem. From my experiences in AutoCAD I think that is something with block creation, In catalog with valves.
    In our project, problem is with check valves.
    I have idea that We must change block with this type of valve directly in folder with block for Plant ...
    I must test...
    Srdjan.
    P.S. idea with layer codification is good, but it seam that doesn't work with some type of valves.
    attila_vallyon
    03-21-2012 12:57 AM in reply to: milic.srdjan
    Yes, the problem with the valves only. The fittings and tubes are OK.
    I realised that the P3d assigns the pipeline layer within the 3D block to the 3D solid when I insert a new valve. But if I insert the same type and size valve on a different line the layer of the valve solid within the block remains the same. That is the problem.
    Maybe if I insert a valve on the 0 layer the P3d won't assign different layer.
    I will try.
    Attila Vallyon
    attila_vallyon
    05-27-2012 02:35 AM in reply to: attila_vallyon
    In the meantime I found a solution.
    Be on the "0" layer always when routing a pipe or inserting a valve block. The software will change the layer automatically according to the line number.
    And when create a new inline element in the cataloge based on custom dwg geometry  set everything to "By block".
    Attila Vallyon
